Wipers refuse to work properly
Old Apr 22, 2017 | 01:32 AM
Ziggy*'s Avatar
Ziggy*
Default Wipers
Put the old switch back in, Go get a contact cleaner from Radio shack or other electrical store, Aim down slot,move switch up an down...Fixed my screwed up 86 switch....Been working...Lots of money that could've been fixed with 2 dollars....My thoughts
Old Apr 22, 2017 | 01:54 PM
TPIGroove's Avatar
TPIGroove
I just noticed this. This is the connector for the motor at the bottom. Is this for a three or two prong motor?
Old Apr 22, 2017 | 02:18 PM
xrav22's Avatar
xrav22
It looks like 2 but I cant remember what mine had. Are you having luck spraying the plugs with electric cleaner
Old Apr 22, 2017 | 02:21 PM
TPIGroove's Avatar
TPIGroove
I was in the middle of doing that when I noticed this issue. I now need to know if this is an issue with the wire or if the motor it had when I got it was wrong all along. If this is the problem, I will have a stroke.
Old Apr 22, 2017 | 02:25 PM
xrav22's Avatar
xrav22
Your issue of the wipers trying to start was exactly my problem and I cleaned all connection but the switch cleaning/plug (at the switch) cleaning made it work perfect again.
Including press once to wipe and spray.
Good Luck
Old Apr 22, 2017 | 04:29 PM
TPIGroove's Avatar
TPIGroove
Good Luck
I just did. Absolutely nothing changed.
Old Apr 22, 2017 | 11:36 PM
gerardvg's Avatar
gerardvg
Hi
My 85 has 3x wires on each connector, there are 3 wires and three connections to the connector that connects to the motor.
I know the 88-96 is a different part to 84-87, if you have 3 wires looks like you will need to replace the wiring harness plug.
The link to a 88-96 wiper motor below it shows 3x terminals.
http://www.ecklerscorvette.com/corve...1988-1996.html
Old Apr 24, 2017 | 11:27 PM
TPIGroove's Avatar
TPIGroove
After looking things over again, I've come to the following conclusions:
1: The cable at the bottom of the motor is normal, apparently. All it handles is the actual motor's rotation, and that has no issue.
2: The issue is definitely related to the connection between the switch and the motor. I'll check the contacts again, but I'm reasonably certain they're fine.
Related to #2, the shaft connected to the bracket that moves the linkage is supposed in a specific manner due to a mechanism on the motor connected to the wiper switch. I'm pretty sure something here is the issue, but I can't determine. The contacts inside the motor are touching the control chip, so that isn't it. Apparently Camaros and Trans Ams from that generation at least use the same motor and general chip setup, so I'm now looking into problems with those cars identical to mine in the hopes I'll find a fix.
Old Nov 1, 2017 | 04:23 PM
RobertLang's Avatar
RobertLang
5th Gear
Dang. I put in TWO new motors. Each ran, SLOW, and then slower, and pushed the fuse HOT until it BLEW -- 25 AMPS.
Old motor runs FINE, but wont completely turn off.
I am about to send the motor to Chicago Corvette and have them rebuild it. I think the circuit that monitors to motor position and the OFF position is bad.
Old Nov 7, 2017 | 04:07 PM
gerardvg's Avatar
gerardvg
I hate to beg for help, but I'm at the end of my rope. I recently acquired a 1988 'Vette that had been garaged most of its life. I'm in the process of restoring it, but one issue I absolutely cannot solve are the wipers. The wipers only activate at the top setting on the switch, and then they barely move, raising up about an inch before going back down repeatedly. I replaced the transmission, motor, motor cover/board, and nothing is physically blocking any mechanical components. I have no idea what could be causing this. I don't know for sure if the switch would cause this or not, and I'd like to know for sure before I burn more money on these things.
Has anyone ever experienced this issue before?
Hi
I had an intermittent wiper not turning off problem the other day,
the motor has a park switch turned out the contacts were loose.
They push into the two motor male spade terminals, the female spade terminals were quite loose making a bad contact.
Simply crimping the female spade terminal does not work they are fragile and break easily, used a piece of tin to push into there to secure it. Works perfect now and the wipers stop / park every time.
Something to check on your old wiper motor..
Old Nov 7, 2017 | 07:46 PM
RobertLang's Avatar
RobertLang
5th Gear
Originally Posted by gerardvg
Hi
iNSIDE THE MOTOR OR MOTOR HOUSING, OR DO YOU REFER TO THE WIRES RUNNING OUTSIDE OF THE MOTOR TO CONNECT TO IT?
Old Nov 7, 2017 | 08:07 PM
gerardvg's Avatar
gerardvg
Hi
when the wiper motor plastic cover is removed, the two contacts can be seen to the right of the large gear.
the two long strips have a contact point that connects to the cover, they are part of the park witch on the motor.
Old Nov 7, 2017 | 08:27 PM
  #33
RobertLang's Avatar
RobertLang
5th Gear
Hi
Cool. Will open and look tomorrow. Makes sense. THank You!
Old Feb 12, 2018 | 10:31 PM
  #34
Mikeceli's Avatar
Mikeceli
OP How about providing CF the courtesy of an update?
Others(including me) could possibly benefit from the info.
