Just uncovered and started my 85 after a cold U.P. of Michigan winter...started right up, everything seem good except it doesn't read the miles per hour anymore...tach and other gages are good....speedometer reads some numbers when I turn the key but goes to O and stays there. Any thoughts on where to start?????
- it might be something as simple as plugging and unplugging the IP cluster's electrical connectors. the OP might not have a good electrical connection (signal or ground). unfortunately, it's a bit of work to get to the panel connectors. batee has a series of 21-youtube videos that covers just about everything on the clusters. whether you repair it yourself or not, a good source of information - covers just about anything you want to know.
