Upper Control Arm Nut Replacement
Old Apr 15, 2017 | 07:34 PM
jimmers's Avatar
jimmers
Default Upper Control Arm Nut Replacement
Curious if anyone knows where I can get a replacement nut for my upper control arm. The nylon lock washer broke when I removed it.
Do you think a replacement is needed? Or would red loctite be enough? I called GM and was told the part is discontinued. I went to a few places around here locally, but no one sells any that big with the lock washer.
Old Apr 15, 2017 | 10:38 PM
THE 383 admiral's Avatar
THE 383 admiral
the C4 control arms do not have nylon lock nuts.
Old Apr 15, 2017 | 10:50 PM
jimmers's Avatar
jimmers
Then what is it? It has some sort of nylon in the nut.
Old Apr 15, 2017 | 10:51 PM
ChumpVette's Avatar
ChumpVette
Just a liberal application of loctite red.
Old Apr 16, 2017 | 09:09 AM
jimmers's Avatar
jimmers
Interesting thanks. It sure doesn't look like Loctite though.
You guys are the best!
Old Apr 17, 2017 | 08:42 PM
jpipx's Avatar
jpipx
Default Yes, they are nylon lock nuts
I just completed my upper control arms and found that these are M20-2.5 steel nylon lock nuts. I purchased six of them, needed to go online since I could not find any local sources for these either.
I found a vendor on ebay that sells them at a reasonable price. Go to ebay and search for item #222388230672
Good Luck!
Old Apr 17, 2017 | 08:53 PM
jimmers's Avatar
jimmers
Good Luck!
That's awesome thanks! I could of sworn it looked like nylon lock nuts.
Old Apr 17, 2017 | 09:05 PM
RUU's Avatar
RUU
Good Luck!
I found them at Fastenall, but had to buy them in a pack of 6 (or 8, not sure).
Old Apr 17, 2017 | 09:24 PM
WVZR-1's Avatar
WVZR-1
I always thought (for this application) the "nylon insert" in the nuts was more of a "sealing device" rather than a locking device due to the use of the dissimilar metals. The bushing/washer provide a seal for the base of the nut.
In very similar nutted (steel/steel) GM would have likely just specified a Prevailing Torque fastener.
To Upper Control Arm Nut Replacement
