Valve lash
Old Apr 16, 2017 | 09:03 PM
skidball's Avatar
skidball
Default Valve lash
Hello,
92 lt1. A year ago. First time ever replacing head gasket and adjusting valve lash. Drivers side. Really had nothing to go by , and no timing marks. Got my information from the forum . Thank you so much. I only adjusted the side the gasket was replaced on, and figured out tdc from the number one valves open and closing. I spun the pushrods until it stopped turning and tighten down about 1 1/2 ish on cold engine. Car runs good, but when at operating temp. Sounds like a sewing machine on the one side. Do I have to go all the way back to step one, or can I go another full turn on cold engine ?
Old Apr 17, 2017 | 02:31 AM
gerardvg's Avatar
gerardvg
Originally Posted by skidball
Hello,
Hi
The general rule of thumb regarding valve lash should be 1 turn from zero lash, however some lifters require less. I found that out with my new engine build, did the std one turn from zero lash and some of the valves were not closing fully.
Did some searching on the lifters manufacturer, turns out they only needed half a turn from zero lash.
The new lifters also needed to be soaked in an oil bath and primed.
I also had a noise issue, i got an old valve cover and drilled holes to allow me to adjust the valve lash while the engine was running.
That got a few loose ones to quieten down.
Old Apr 17, 2017 | 10:53 AM
9T3VETTE's Avatar
9T3VETTE
Originally Posted by gerardvg
Hi
Going to be doing a cam swap here soon. Can you elaborate a bit more on the soaking the new lifters and priming?
Old Apr 17, 2017 | 01:50 PM
Need A Vette's Avatar
Need A Vette
Take the new lifters and soak in oil, I normally do it for 24 hours, and right before install, I actually pump the actuator of the lifter a few times until no bubbles come out. As an additional step, I would also turn the oilpump with a drill, once everything was back together, until it develops pressure. Easy stuff...
Hope it helps.
D.
Old Apr 17, 2017 | 02:27 PM
9T3VETTE's Avatar
9T3VETTE
Hope it helps.
D.
Great, thanks this is what my assumption would be. To be clear priming with a drill would occur after lifters, pushrods and rockers are installed and lash is set on all 16?
Old Apr 17, 2017 | 02:51 PM
Need A Vette
Absolutely, that's how it's done, just have to pull the distributor...though not sure on an Opti engine...
D.
To Valve lash
