Overheating and I don't know why
- bad radiator cap?
- bad thermostat?
- Blocked hose or radiator?
- Head gasket blown?
- water pump not pumping?
It does not seem down on power, The overheating may be due to the coolant lose? I am not understanding the problem
- bad radiator cap?
- bad thermostat?
2. Empty pipes?
3. Does the fan work?
4. Does it come on at temperature? If not, the system will heat up and dump all the coolant out of the radiator cap into the header tank. If the fan is working, check the thermostat.
5. Got any high temp figures on the dash?
6. Warning lights?
7. Do all the pipes feel hot when its running?
8. Does the fan blow hot air when it should?
- bad radiator cap?
- bad thermostat?
Check your radiator cap, it should be 15 psi or 16 psi.
What temperature does the dash show does it run at normal temperature then rises as coolant is lost?
Check the space between the a/c condenser and radiator, leaves twigs all get caught up in there blocking airflow. That could result in coolant loss if it overheats.
Does the cooling fan work?
could most likely be a bad radiator cap?
From memory it should only transfer a small amount like a pint of so to the recovery tank, during normal temperature 190F-230F
The fan is controlled by ECM if you have the booster fan in front of a/c condenser and main cooling fan behind radiator.
The ECM doesn't start the cooling fan until around 230F
Over 250F i would expect more coolant venting into the recovery tank, can hear bubbling noises if it starts to boil.
This all depends on your coolant mix, i use 50% antifreeze anti boil coolant concentrate with water.
That should raise your boiling point to around 260F with a 15 psi radiator cap, if your coolant is boiling below 260F and you have a 50/50 mix your radiator cap is faulty. Pressure raises the boiling point also.
Good luck
Your description suggests exhaust gases are entering the cooling system super heating the coolant, and forcing coolant into the overflow bottle.
The cooling system and block can be pressurized to confirm a problem gasket, and there is a simple test that can detect exhaust gases in the coolant.
2. Empty pipes? Radiator is full, hoses are not collapsed
3. Does the fan work? I will check
4. Does it come on at temperature? If not, the system will heat up and dump all the coolant out of the radiator cap into the header tank. If the fan is working, check the thermostat. I am thinking about removing the thermostat entirely as a test
5. Got any high temp figures on the dash? floats around 160-180 when dumping coolant, then straight to >230, when I shut it down. It runs at about 180 on the highway and rarely above 220 on the street. I think years ago I had the computer turn on the fans at a lower temp.
6. Warning lights? None
7. Do all the pipes feel hot when its running? Yes, and firm
8. Does the fan blow hot air when it should? what fan? The heater works and helps with cooling, the radiator fans work - I think, but I will check
What temperature does the dash show.....It always ran cool, i think I switched out the stat to 180 years ago. It floats around below 180 for a time than when it loses coolant, it goes up to 230 fast. At that point I shut it down
Does the cooling fan work? I will check
could most likely be a bad radiator cap? Yep, will buy today
The fan is controlled by ECM.... I think I can jump this direct to 12V and force them to run 100 percent and check
if head gasket, would get a steady stream of small bubbles in reservoir, not a gallon dumped after 10 minutes.
try not to drive car like this or might really cause head gasket problem.
that chemistry test in vid is spot on, dude knows the n* is toast and knows not to even bother to try replacing that hg, likely caused by overheating.
and just for clear communication, the tank with the cap is the 'reservoir, high fill', the other tank near the headlight is 'reservoir, coolant recovery'. From which tank is the gallon dumped, reservoir tank or recovery tank?? That will answer good cap or bad cap.
This is a slow moving project, but I did buy a thermostat and a radiator cap. I put the new cap on and ran the car in the garage. It heats to 220, the fans come on and then it drops to 210 and stays there - cool.
So I took a ride and it runs great until about 20 miles out. Then I had a runaway and the temperature goes up until I shut it down.
The radiator is cool (cold) until there is a run away. Thermostat stuck????
