Distributor modification for clamp down HEI Cap Rotor
Old Apr 19, 2017 | 05:11 PM
cache1's Avatar
cache1
Default Distributor modification for clamp down HEI Cap Rotor
1990 L98
A previous owner had a MSD HEI distributor ignition installed, and I suspect they passed down a problem for me to inherit...
It appears the original distributor cap 'bolted' down to the base, but the MSD distributor caps are designed to 'clamp' down with 'L' shaped bolts on a spring that rotate 180 degrees to slide under the bottom part of the distributor that holds the cap. Apparently this issue was solved previously by removing the clamping bolts and spring that came with the MSD cap and replacing them with regular hex head bolts to bolt down the cap (recessing them down in the deep wells). This became a problem for me after I pulled the distributor to do a head gasket repair and had to reset the timing. The wells were too narrow to fit a 1/4" socket down to loosen the bolts (I have no idea how they were tightened in the first place). I had to cut the wells off the cap to get to the bolts, and I have ordered a new cap which is coming with the 'clamp down' bolts in it.
This all brings me to a decision I have to make. The base of the distributor appears to have been molded with tabs to 'bolt down' to, but also have the recessed areas to be clamped to, but the recessed clamping locations cant be accessed unless the bolt tabs are ground off. So, the question is do I grind off the tabs, so I can install the new cap in stock condition? or, do I modify the cap with new bolts to go into the distributor base as-is?
Old Apr 19, 2017 | 05:48 PM
WVZR-1's Avatar
WVZR-1
You don't modify the distributor to use anything! Get the correct cap with the correct hardware.
Old Apr 19, 2017 | 06:09 PM
cache1's Avatar
cache1
I agree that would be the ideal, but it doesn't appear to be an option to do that and try to keep some of the existing parts. The MSD website, O'Reillys, and Summit Racing came up with no MSD 'bolt down' cap that would match with the existing coil/rotor/dustcap.
Old Apr 19, 2017 | 07:40 PM
WVZR-1's Avatar
WVZR-1
Then just match a machine screw with the correct thread and a head that has dimensions that will drop into the "wells" (your terminology) of the cap that you already have and maybe haven't ruined or use a new cap MSD, or whatever!
Old Apr 19, 2017 | 10:25 PM
Churchkey's Avatar
Churchkey
Some Caddy's also use the screw on cap.
If you want to keep the MSD brand cap:
Whiz wheel the 4 "L" tabs off, whiz wheel a slot for a screw driver in the head of each stock bolt.
Old Apr 20, 2017 | 04:49 AM
Joe C's Avatar
Joe C
Old Apr 20, 2017 | 06:10 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I used philip head srcrews and a philip screw driver, works best with a magnetic tip.
Old Apr 20, 2017 | 08:04 AM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Biggest problem is too many places list the incorrect clamp down style cap as the correct cap, Rock Auto, Advance Auto, etc. The only local store I found that had the correct cap was Autozone.
Old Apr 20, 2017 | 01:38 PM
cache1's Avatar
cache1
I did already ruin the old cap by slicing off the recessed bolt holes (aka 'wells'). I had to, to get the cap off to access the rotor and set the initial start position for timing. The new cap hasn't arrived yet, but when it does, I'm going to see if I can straighten the 'L' shape bolts that come with the new cap and thread them to screw into the existing distributor base. No grinding, and everything a near to stock condition as possible. (grinding was never sitting right with me anyway, but you know how it goes when brainstorming for solutions, sometimes they are ).
Old Apr 20, 2017 | 01:45 PM
cache1's Avatar
cache1
The recessed bolt holes appear to retain a spring which keep tension on the L shaped bolt while clamped. The cap I inherited didn't have the springs, I think they were tossed and the, impossible to remove, hex head bolts tightened down to the bottom of the holes. But you are absolutely correct, the new bolting setup for the cap will have Phillip heads or something similar.
Old Apr 26, 2017 | 06:22 PM
cache1's Avatar
cache1
CONCLUSION:
I removed the 'L' shape bolts that came with the new cap and replaced them with a socket (aka allen) bolt, with a low profile head, so it could recess down into the 'wells' and compress the springs, ultimately holding everything snug.
In hind site, it may have been better to just put an OEM cap and rotor back in, and undo the hi performance one installed, because the 'upgrade' is bigger in diameter and makes things very tight (you have to bend the rubber seal for the hood back, and the plenum can get in the way for adjusting the tuning). Oh well live and learn. A professional mechanic friend of mine said "'Spark is spark', you probably are not gaining anything with the aftermarket 'hot rod' cap and rotor".
Old Apr 26, 2017 | 07:56 PM
WVZR-1's Avatar
WVZR-1
CONCLUSION:
What thread did you determine the housing tabs required to accomplish the modification to use? The socket head was likely the easiest find, a machine screw with a spinning washer might have been ideal if it would drop into the depressions of the cap.
OEM cap certainly a maybe better option!!
Old Apr 28, 2017 | 08:04 AM
BOOT77's Avatar
BOOT77
I didn't read all the replies but someone on here once just cut the hooks off n used the screws from the old cap in the new ones holes, mod the cap not the dist.
Old Apr 28, 2017 | 11:15 AM
cache1's Avatar
cache1
Replacement bolts working great!! (Not tightened down yet)
Fit nice into the recessed 'wells'!
Old Apr 28, 2017 | 11:29 AM
WVZR-1's Avatar
WVZR-1
And the thread size was?
Old Apr 28, 2017 | 11:47 AM
cache1's Avatar
cache1
Sorry, I saw your question above but didn't know the answer, and still don't, exactly. I took the old bolts to Ace Hardware, and they have a size gauge on the wall so you can determine the size and thread, which I did, but cant remember what the numbers are now. I know the new ones I bought are 2" long. And If I were to guess the thread and diameter I'd say 10-24.
To Distributor modification for clamp down HEI Cap Rotor
