easy question, which way does the engine spin?
Old Sep 27, 2002 | 01:06 AM
Nathan Plemons's Avatar
Nathan Plemons
Default easy question, which way does the engine spin?
If you're sitting in the car, which way does the engine turn? My gut tells me clockwise but it's late and I can't be sure.
Also, a friend of mine told me that Fords actually turn the opposite direction of GM products. Any truth to this?
Old Sep 27, 2002 | 01:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: easy question, which way does the engine spin? (Nathan Plemons)
It turns CCW looking from the driver's seat; CW looking from front back.
Old Sep 27, 2002 | 01:21 AM
vader86's Avatar
vader86
Default Re: easy question, which way does the engine spin? (65Z01)
Old Sep 27, 2002 | 01:34 AM
Ericthewolf's Avatar
Ericthewolf
Which way do your belts spin>> I would say this would be a pretty quick way to figure it out>>> :jester
Old Sep 27, 2002 | 09:25 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Not only that, there are some engines used in boats that spin the opposite way.
Old Sep 27, 2002 | 09:51 AM
vettmech's Avatar
vettmech
Default Re: easy question, which way does the engine spin? (Mr Mojo)
No, all front engined rear drive American engines spin the same way....... EXCEPT for some dirt track race engines....... the are reversed on purpose to plant the right rear tire instead of lift it......... :seeya
Old Sep 27, 2002 | 10:25 AM
89vette's Avatar
89vette
What??? I didn't say that :blueangel:
[Modified by 89vette, 9:00 AM 9/27/2002]
Old Sep 27, 2002 | 10:44 AM
Nathan Plemons
:lol: I guess I'll just go have to look. Seems like if I punch the gas while sitting still it torques the car to the right, that's why I was thinking clockwise but my physics could be a little fuzzy.
Old Sep 27, 2002 | 10:47 AM
Red91C4's Avatar
Red91C4
Default Re: easy question, which way does the engine spin? (vettmech)
Rotation is CLOCKWISE as viewed from the front of the engine. Even FORDS.
Multi Engined boats have one engine that is reversed.
Old Sep 27, 2002 | 10:55 AM
scorp508's Avatar
scorp508
Yup, definitely CCW from sitting inside the car. When you use a timing light and you are "before top dead center" where is the timing mark on the balancer? Before the 0 mark closer to the top of the engine. When you are "after top dead center" where isthe timing mark on the balancer? After the 0 mark closer to the bottom of the engine. So the balancer is rotating TOWARDS you when you are standing there.
Old Sep 27, 2002 | 11:29 AM
Mr Mojo's Avatar
Mr Mojo
For every action, there is an equal and opposite reaction:)
Old Sep 27, 2002 | 11:43 AM
semvhu's Avatar
semvhu
Okay, now MY physics must be off. It's been shown that American engines rotate CCW. This tries to rotate the car CW as sitting in it, so that puts more pressure on the right side of the car, correct? What am I missing?
Ah, of course, the midget classes, or whatever they're called. Those are rear-mounted engines, correct? So those would be turned 180 degrees compared to a front mounted engine. If they turned the same direction, you now have the engine torquing the car to the left, not the right. Making them run with opposite spin will now put pressure on the right side of the car.
Now I can say :smash: :D
Old Sep 27, 2002 | 11:45 AM
scorp508's Avatar
scorp508
The engine torques the frame in such a way that the right rear gets light. This is why you will commonly see battery relocation kits mounted over the right/rear tire. :)
Old Sep 27, 2002 | 01:29 PM
vader86's Avatar
vader86
Default Re: (scorp508)
The resident physics major says Scorp is right.
Old Sep 27, 2002 | 01:58 PM
lead_foot's Avatar
lead_foot
From the driver's seat the crank shaft is turning in a CCW direction. This in turn attempts to turn the block in a CW direction, the equal an opposite reaction. The engine block torque is transfered to the frame through the engine and tranny mounts. Thus trying to rotate the car body in a CW direction. If the block wasn't fixed it would try to spin round and round just like the crank shaft. This is similar to a helicopter that loses its tail rotor. The body of the helicoper begins to spin because there is nothing to counteract the torque.
To easy question, which way does the engine spin?
