92 No start (no turn over)
Old Apr 21, 2017 | 07:27 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default 92 No start (no turn over)
I have a 92 automatic that won't start. Simple enough? Well The battery is up. I used a jumper wire and the solenoid pulled in an engine turned over. So the starter works ok. It won't turn over with the key switch. I believe that leaves me with several unchecked items starter switch, wiring, neutral safety switch, and ECM. I forgotten how tight everything is on these cars. What is everyones opinion as to the most likely problem? I have driven this car exactly once it was a Mecum Auction Special. That is a whole nother story.
Old Apr 22, 2017 | 04:06 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
history?
i think it is vats.
Old Apr 23, 2017 | 07:49 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
My 96 drove me nuts with a similar situation. I see you've jumped the starter, and it worked okay.
So did mine.
After chasing my tail for a week or so I pulled the starter and lo and behold the contacts were toast. I swapped them out and have'nt had another problem.
later, tiny
Old Apr 23, 2017 | 10:36 PM
87bob's Avatar
87bob
Default Found the problem!
I switched and went to the other key and all worked well.
Old Apr 23, 2017 | 10:45 PM
geb@abq's Avatar
geb@abq
ok. So it was the VATS ?? or you are just a DF and don't know ----just so people know
Old Apr 24, 2017 | 09:36 AM
87bob's Avatar
87bob
Since the other key worked fine, the VATS must be ok. And since you couldn't figure that out it leaves you to figure out what you are.
People come here for help from those in the know, not snide remarks.
Old Apr 24, 2017 | 09:36 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Well damn....Ive never run into that before, makes me wonder why the first key quit working.
later, tiny
Old Apr 25, 2017 | 11:32 AM
geb@abq's Avatar
geb@abq
Hello 87 Bob. I apologize for the "snide" remark, it was rude of me to make the smart-a**ed comment, and I am glad for you that the problem was just the key. I am myself having a VATS problem and have ordered a bypass for it. I went to a locksmith yesterday and had a new key made, and it doesn't work either, so the bypass. When I initially started having this problem, I checked the fuses, replaced the starter relay, and rebuilt the starter solenoid, and finally settled on the problem being VATS related, as it was intermittent, and after 10-15 minutes would sometime crank with the key for no apparent reason. I surmised that maybe the contacts in the ignition switch were dirty, and squirted some some MAF sensor cleaner in it and blew it out with compressed air, and think that made it worse for whatever reason. Won't start no at all now. Again, sorry for the remark
Old Apr 25, 2017 | 06:57 PM
geb@abq's Avatar
geb@abq
ok, my problem was VATS. Ninety five cent resistor cured it, good thing I got a $30 part (bypass kit) on the way...oh well, at least I have an extra key now
To 92 No start (no turn over)
