Battery Issue
Old Apr 22, 2017 | 01:28 PM
James84vette's Avatar
James84vette
Default Battery Issue
Would anyone know the exact bolt that needs to go into the positive slot in the battery? When I bought the car someone had the wrong sized bolt. Once and a while I go to start and just hear that clicking sound. I take a pair of pliers tighten it and we are good to go. I went to a local car parts place and they gave me a bolt but it's doing the same thing. Drive the car around for a bit, it's fine then it must loosen. Not a big deal but I'd like to have the proper bolt to connect the positive terminal correctly.
Thanks.
Old Apr 22, 2017 | 03:16 PM
hcbph's Avatar
hcbph
You can use something like this: http://www.oreillyauto.com/site/c/de...26+accessories
or go to your local hardware store and pick up a 7/16" bolt of the correct length. That's what I use when I'm charging a side mount battery.
Old Apr 22, 2017 | 06:27 PM
James84vette
Ok will do. Thanks. Should I being using lock right in the bolt as well?
Old Apr 22, 2017 | 07:35 PM
A Peter C4's Avatar
A Peter C4
Do not use lock-tite, be sure insulation on cable allows full contact with battery and that bolt does not bottom out in battery before it clamps cable to battery. I had this problem and had to use a longer full thread bolt with a nut on it, bottom it out in battery and then tighten the nut on to get the cable to have good contact. someone had partly striped the threads in the battery and I could not get a good tight contact at positive cable,also had to trim some of insulation off the cable, the thin ring that fits tight into positive post to allow the cable to seat correctly.
Old Apr 22, 2017 | 07:39 PM
James84vette
Ok, I'll do that then. Orgially it had a loner boltnwith a nut on the end but like I said before it would continue to get loose. I did cut off that red ring as it was in the way of a new bolt I got. I'll take it off and make sure the cable goes flush to the battery.
Old Apr 22, 2017 | 07:49 PM
A Peter C4's Avatar
A Peter C4
Trim the ring on the battery side of the cable.
Old Apr 22, 2017 | 07:50 PM
tlong's Avatar
tlong
Mine is an 8 metric. Don't take this wrong but you need to put a good battery in there. The MvGyver attitude can only work for so long, then you are dark out on a blacktop when a beat up pickup pulls up to help.I saw Deliverance 14 times.
Is happy motoring worth $75? Hell yes it is.
To Battery Issue
