I bought a t56 6 speed and it came with a valeo dual clutch but it was for a sbc and I need it fit my Pontiac 400 flywheel the pressure plate and clutch steel bolt up to my flywheel but I don't know how to shim it the guy I bought it from said it had to be perfect and not to move the shims he had them all numbered
What is the car? Why does a C4 Corvette have a Pontiac flywheel? What is the actual problem? If the PP bolts to your FW, and the FW is flat...then it should work fine. Unless you're concerned with the actual depth of the FW/PP in relation to the throw out bearing? We don't know. Help us, help you.
