remove and replace the k member / engine cradle.
Old Apr 29, 2017 | 04:43 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default remove and replace the k member / engine cradle.
anybody rnr'd the front k member or cradle after hitting a rock on the road?
can this be done by supporting the oilpan and trans pan with wood blocks and then unbolting engine mounts et al and dropping k member / cradle out the bottom?
I did search and found one thread from way back but no threads logging the experience.
comments appreciated.
VT.
Old Apr 29, 2017 | 05:08 PM
s carter's Avatar
s carter
VT.
I have replaced a couple in my dealership day's, It is a bit of a chore but Would recommend using a Engine Hoist or some other holding devise, along with less chance of Damaging the pan and you will probably need the space if your doing it on your back.
If your doing it on a lift use a thick board or plywood with some R-Board between wood and oil pan to spread the load, whatever you support it with make you trust it.
Old Apr 29, 2017 | 09:13 PM
frankinvett84's Avatar
frankinvett84
Ditto...I replaced mine with one from a newer model..thought about it for a while ...then just pulled the engine ..I left the trans , I ratchet strapped the trans up hooking it on The braces by the hood latches... wasn't as bad as I thought it would be...
Old May 2, 2017 | 03:14 PM
VikingTrad3r
Oil Producer
looks like I am doing a engine cradle swap on my 1987. Has anybody out there done this in their garage without Engine pull?. If so, what was used to support the engine and transmission. What blocks? That's what I'm thinking. I have a supply of six by sixes I can cut up.
Old May 2, 2017 | 04:24 PM
s carter's Avatar
s carter
I did one on the Body Shop floor WITH OUT A LIFT and not pulling the motor, I used floor jack under the pan for some, But also do remember using the Engine Hoist to support at one point leaving all in the air while we swapped the frames.
I think the hoist was used to get space under the car and I was concerned with possibly damaging the pan.
Old Aug 20, 2019 | 03:03 PM
VikingTrad3r
Oil Producer
yes i am bumping my own thread.
its finally time for me to swap the k member on my 87 and then sell it off.
question for anyone who knows....im at my local vette shop and they have a boneyard...what year of k member will swap over with my 87 exactly?
84-87?
Old Aug 21, 2019 | 09:48 PM
VikingTrad3r
Oil Producer
Originally Posted by ihatebarkingdogs
84-87 = P/N 14093126
88-91 = P/N 10080751
My fiche doesn't have a listing for 92-up. Kind of odd. I know those cars have the part. My fiche was issued Nov, 2001. both P/N's above were DISCON at the time.
thanks. found an 86 for 250$ from my local boneyard up here in yyc.
hard to believe this 87 has been sitting lame for 2 years!
will be nice to get it fixed and out the door.
Old Aug 23, 2019 | 08:28 PM
VikingTrad3r
Oil Producer
time to get busy!!
Old Aug 3, 2021 | 06:17 PM
Brett Passmore's Avatar
Brett Passmore
7th Gear
So, how did this go?
Old Aug 4, 2021 | 12:01 AM
VikingTrad3r
Oil Producer
It went great. No trouble. Are you doing it?
Old Jan 5, 2022 | 12:49 PM
Brett Passmore
7th Gear
Sorry I missed your reply, I didn't get a notice.
I did, and it was very easy. I was surprised!
Old Jan 5, 2022 | 01:33 PM
VikingTrad3r
Oil Producer
great! i dont suppose this was for the alberta car that drove over a pieice of steel c channel?
Old Jan 5, 2022 | 01:36 PM
VikingTrad3r
Oil Producer
incase anyone finds this, i documented the procedure here:
https://www.corvetteforum.com/forums...oked-rock.html
To remove and replace the k member / engine cradle.
