CFM required for 300RWHP performance?
Old Sep 27, 2002 | 05:47 PM
LD85's Avatar
LD85
Default CFM required for 300RWHP performance?
Hey guys my Lingefelter and Chevy Perfomacne books I bought from Amazon have not arrived yet so I am wondering about the amount of CFM that the system needs to flow from the plenum thru the runners and thru the heads. This to achieve 300RWHP
This may be a whacked out question so slap me if its :lol:
Old Sep 27, 2002 | 05:48 PM
scorp508's Avatar
scorp508
No clue, but you'll need about 365 at the crank.
Old Sep 27, 2002 | 05:53 PM
Bluevette85's Avatar
Bluevette85
Default Re: CFM required for 300RWHP performance? (ld85)
I have both those books and don't remember seeing any clear numbers.
Old Sep 27, 2002 | 06:05 PM
MrNuke's Avatar
MrNuke
I dun think thats an exact science.
I've seen cars with BONE stock engines and just a supercharger
and they flew enough for 400+HP at the Rear wheels even.
Even If you get enough flow for like 240cfm+ through the heads,
more than 800 through the TB/plenum (800 is a VERY good port job with 52mm TB I believe), it won't help get to 300HP at the wheels unless you change at least the cam in there.. You need to worry about flow #'s once you already have the 'demand' of your engine for them. Going the other way around won't help you much.. :cheers:
Old Sep 27, 2002 | 07:28 PM
LD85's Avatar
LD85
Default Re: CFM required for 300RWHP performance? (MrNuke)
The heads will be ported to at least 240 CFM and I will use a Super Ram with a cam that is right for the setup!
I guess I probably have answered my own question. The SR will flow in excess of 240CFM as will the ported de-screened and de-finned stock Throttle Body. So the heads will create some back pressure in the system. I will wait for flow numbers on the heads to determine the cam specs.
Old Sep 27, 2002 | 07:30 PM
scorp508's Avatar
scorp508
You're overcomplicating things. :) My heads are ported D-ports with larger valves also. Pulled 322rwhp (388 bhp) without any tuning.
To CFM required for 300RWHP performance?
