tune up time
Old May 7, 2017 | 04:49 PM
onDjuice's Avatar
onDjuice
Default tune up time
I got a 1992 corvette. Has any one put a later distributor (96) vented style on a early style one. I,m doing wires and want to change the cap and rotor at the same time.. Thanks
Old May 7, 2017 | 05:14 PM
don hall's Avatar
don hall
If your opti is original, you might consider replacing it with a vented
opti: https://www.corvetteforum.com/articl...acement-guide/
There are other vented opti
instructions..... search will help.
If the opti has been replaced, you might just leave it alone until it fails.
Then consider a vented opti. Just a humble suggestion.
Old May 7, 2017 | 06:17 PM
onDjuice's Avatar
onDjuice
It looks factory (92) car works fine. Thanks for the info bro..
Old May 7, 2017 | 08:32 PM
A Peter C4's Avatar
A Peter C4
How they say, if it's not broken- don't fix it. Also stock type 96 needs to change timeing cover components on pre 95 or buy updated type for your car.
Old May 8, 2017 | 09:37 PM
scotth48's Avatar
scotth48
Some aftermarket opti's offer a vented system for the 92-93. I have a Dynaspark that I bought a long time ago as a spare that I finally pupuit on. Don't Know if they are in business yet as ownership changed after I bought mine and heard that the quality of the units decreased because of poor parts used. I think they did not use the Mitsubishi sensor in the latter units.
To tune up time
