I have done the searches, seen the threads where guys built their own tool but the pictures are no longer hosted. I know I need a longer than stock bolt but besides that this piece is the only thing holding me back.
Does anyone have pictures or a guide to a build your own tool with pictures.
get a 7/16th fine thread cap screw, long enough to screw all the way into the crank snout with the cap screw head sticking out beyond the end of the hub
set up a normal three jaw harmonic balance puller with the threaded arbor pushing against the cap screw head, tighten
the hub will pull forward until it contacts the bottom of the cap screw head
replace the 7/16th bolt cap screw with a longer one, reset the three jaw puller and repeat
do this two or three times and the hub will come off
Are you doing it with the half-shaft in or out? If you pull the half-shaft out, you have total access to check the u-joints and Teflon washer, plus easy access to the torx bolts that attach the hub to the knuckle.
just something to think about.
