A/C compressor always on
I got the schrader tool and valves, orifice tube and was all set to vacuum it out. I was able to tighten the low side schrader valve but not the high. Then I realized (should have before) that the high side connect looks different. Is this a different type of schrader valve? See pics 1 (low) & 2 (high) and the tool I bought (pic 3). I think I saw a thread that the high side is a different kind of valve.
While I'm here, can someone confirm that the orifice tube I bought is the right one? The FSM is useless for the AC pics so I posted asking for the location of the orifice tube on another thread but if someone has that too, great.
The Schrader valve removal tool you have is really for tires. Even though the valve is a physical fit the length of the tool may not be long enough. AutoZone also sells this tool which looks like a screwdriver but the shaft has a long reach to get deep in there.
Bought some orifice tubes for my 94 which I have not used yet but should be the same part as a 96. It's a Santech MT0097.
There is also a orifice removal tool. I borrowed it from AutoZone but would not fit in due to the physical confines. I built a tool which should work but have not used it yet. You may not want to mess with the orifice tube if you don’t have to.
Back to autozone I guess.
re: orifice tube. I watched a bunch of videos and they seem to show very clogged orifice tubes. So why wouldn't I want to put a new one it if I have to vacuum the system anyway?
Yes, I think you should change the orifice. Very simple to do, just make sure you install it correctly, it is directional. I have changed several, and they all have had "debris" on the screen.
BTW - these are $4 while autozone has them listed at $13. I hope these aren't the ones that fail quickly!
Anyways, after about 12 oz of 134a, the system was working properly and as I kept filling the compressor did not pull down the low side enough to shut it off. So I emptied a little 134a and it was again cycling nicely (roughly 10 seconds on, 3 seconds off) and the temperature at the vent was 42F.
So the system is working but on only 12oz on 134a. How is this possible or what am I doing/measuring incorrectly?
