Oil temperature sensor location LT1 ?
Old May 14, 2017 | 09:03 AM
Cool Runnings's Avatar
Cool Runnings
Default Oil temperature sensor location LT1 ?
Oil temperature gauge not working, figure it's most likely a bad sensor. Where on the engine is the sensor located?
Old May 14, 2017 | 09:34 AM
WVZR-1's Avatar
WVZR-1
I don't believe that the EOT changed year to year SO ...... rear of left side engine @/near/above oil filter vicinity. Does year matter?
Old May 14, 2017 | 09:39 AM
Cool Runnings
Thanks. Will I have access from the top?
Old May 14, 2017 | 09:54 AM
WVZR-1's Avatar
WVZR-1
i believe that first thing would be to confirm failure. You have no EOT displayed on both the gauge and the "digital display"?
Old May 14, 2017 | 12:00 PM
Cool Runnings
Will check digital display, just noticed the gauge seems stuck at 100 F.
Old May 14, 2017 | 12:33 PM
don hall's Avatar
don hall
Is this similar to your gage reading? If so, that is normal. Max movement for analog oil temp needle is about ⅛". Sensor is located in the
base of the oil filter housing. Access is limited/difficult. This photo must have been taken when engine was first started.
Old May 14, 2017 | 03:51 PM
Cool Runnings
Thanks, finally got her out on the road for a spell in 80F, Oil temp gauge went to about 1/4. Mine has halfway markers too. Guess it's normal - thanks.
Old Aug 23, 2023 | 02:01 PM
thedave8's Avatar
thedave8
sorry, i know this is an old thread, but was oil temp sensor screwed into the oil filter adapter port, or the engine block itself...i got stuck putting together a 94 vette that someone else took totally apart, like other jobs i have posted about....
Old Aug 23, 2023 | 03:00 PM
WVZR-1's Avatar
WVZR-1
Old Aug 24, 2023 | 08:30 AM
thedave8's Avatar
thedave8
thank you!!!!!
To Oil temperature sensor location LT1 ?
