Injectors size?
Old May 14, 2017 | 11:18 PM
Opa's Avatar
Opa
5th Gear
Default Injectors size?
Installing Super ram, 52 mm BBK throttle body and 1.7 roller rockers. Can I use my stock injectors?
Old May 15, 2017 | 11:40 AM
vader86's Avatar
vader86
Need to know more about the engine, heads/cam change? staying 350?
Old May 15, 2017 | 12:03 PM
Opa's Avatar
Opa
5th Gear
Yes engine and heads are stock. Adding catbacks but nothing else for now.
Old May 15, 2017 | 12:04 PM
Opa's Avatar
Opa
5th Gear
Wondering if the ECM will need a retune.
Old May 15, 2017 | 01:08 PM
vader86's Avatar
vader86
I have done it, yes you can stick with stock injectors. You're only adding an intake change.
However, it will have dead spots and surges in the power band. It would be better with a tune, but it will not be worlds-better than stock. The cam is just too small.
To Injectors size?
