fuel starvation
Old May 17, 2017 | 01:58 PM
kocoach's Avatar
kocoach
Default fuel starvation
I have a 1987 corvette I recently installed a new motor from a1992 corvette with an actual 100 miles on it. Installation and fitment was fine but now I notice when turning corners slow or fast it seem as though the motor starves for fuel it is unresponsive until I straighten it out and then fuel power is restored and it runs great until I have to turn again. A new fuel pump was installed, as well as new plugs and wires , water pump the list goes on and on. Does anybody on the forum have any ideas as to what the problem could be? Thank You
Old May 17, 2017 | 02:41 PM
don hall's Avatar
don hall
You might test your fuel pressure:
Old May 17, 2017 | 02:43 PM
kocoach's Avatar
kocoach
Pressure is where it's supposed to be. Thanks
Old May 17, 2017 | 02:44 PM
c4cruiser's Avatar
c4cruiser
What is the fuel level in the tank when this happens? C4's seem to want a minimum of 1/4 to about 1/3 of a tank to keep this from happening.
The bottom of the tank is supposed to have a way to contain some fuel around the pickup. There is a strainer that mounts to the fuel pickup and it is supposed to fit down in that area.
You may want to remove the fuel pickup/pump assembly (again) and check for anything that may prevent gas from staying in that area. Check to make sure the fuel lines are securely attached to the pump and pulsator. Could be that the strainer has come loose. Do this when the tank is nearly empty so you don't have to siphon out lots of gas.
Old May 17, 2017 | 02:58 PM
aklim's Avatar
aklim
Have you done a WOT run yet? Check that out and see what it does when cornering.
Old May 17, 2017 | 03:01 PM
aklim's Avatar
aklim
IDK. Mine was always driven till the "E" mark and some before it gets a full tank. Rinse and repeat.
Yes, I have the baffle. If the baffle comes off or has been removed, I suppose it can cause issues.
That might be a good point. Perhaps it is the pulsator that came loose or is dumping gas out of the system and back into the tank.
Why? It comes from the top. On my Excursion with a 44 (but I have driven it to 46 gallon fillups) gal tank, it is nothing short of fun. I took out the filter in that one and ran an external filter.
Old May 17, 2017 | 04:09 PM
kocoach's Avatar
kocoach
Brand new float and pump assembly, it does it with a full tank of gas as well as when little gas left in tank.
Old May 17, 2017 | 04:15 PM
aklim's Avatar
aklim
Did you replace the pulsator with fuel hose?
Old May 17, 2017 | 04:28 PM
kocoach's Avatar
kocoach
That I don't know? I'm partially dis-abled so I' have a very reputable repair shop do the work, I'll let them know to check it out. This is costing a small fortune anyway. Thank You
Old May 17, 2017 | 04:31 PM
kocoach's Avatar
kocoach
I'm not familiar with a WOT.
Old May 17, 2017 | 04:38 PM
TA's Avatar
TA
Wide Open Throttle
Old May 17, 2017 | 04:40 PM
aklim's Avatar
aklim
Check or have someone near you check. Asking is free
Old May 17, 2017 | 04:42 PM
aklim's Avatar
aklim
Tape that gauge to the glass and hit the throttle wide open and see what happens with the pressure
Old May 17, 2017 | 04:46 PM
kocoach's Avatar
kocoach
I informed the mechanic and he knew what WOT was and they will be checking that out. Thank You for your input.
Old May 17, 2017 | 05:29 PM
DGXR's Avatar
DGXR
Some of the engine sensors will cut power if they detect a potentially damaging condition, such as low oil, low coolant, some others I can't think of right now. You may not have low oil or low coolant but if the sensor is bad or going out (or sending odd signals) then it might cut the power. Just a thought.
Old May 17, 2017 | 08:24 PM
aklim's Avatar
aklim
Only one I can think of that will do anything of that nature is the oil pressure sensor and under certain conditions. There are 2 sources of power and the oil pressure sensor is the backup. So, if that is correct, the main circuit would have to fail and the backup kicks in. When the pressure is low, power would be cut. Kinda stretch but that is all I can think of.
Old May 17, 2017 | 08:32 PM
Benny42's Avatar
Benny42
Low oil pressure will not cut off the fuel if the fuel pump relay is good. Look elsewhere for the problem
To fuel starvation
Old May 18, 2017 | 04:40 AM
383vett's Avatar
383vett
The oil pressure switch provides a secondary circuit for the starter. It will not **** the motor off.
Old May 18, 2017 | 07:35 AM
bjankuski's Avatar
bjankuski
I am curious, a 1992 engine is an LT1, the 1987 engine is the L98. What computer system are you using to run the engine? Did you swap over all the supporting parts to correctly install the LT1? (Cooling system, computer, wiring harness so forth and so on)?
The initial item that I would check would be to monitor the fuel pressure while driving the car and see what it does when you notice the problem. With that being said, since this is a engine swap it could be something less obvious so scanning the car may be necessary to see if timing or something else is going on. That is why I am asking about how the swap was performed.
Old May 18, 2017 | 10:44 AM
DGXR's Avatar
DGXR
I must have been fed (and willing to eat) some wrong information. My bad.
