Rear lowering complications
Right side, 43 mm fender/wheel gap, its about half as low as it will go.
The right side has a nasty negative camber
The left side has a little bit of a positive camber(picture didn't turn out). The right side is within the fender, the left side sticks out a little bit.
Other than the fact that its not even, it looks a lot better than stock:
This is a bad angle, but still. :cool:My thoughts are that since I was trying to even out the left side, by running the bolt ALL the way down, it pulled the suspension out of kilter. I'm about to go out and set them both about even bolt lengths and see what happens.
BTW, it was pretty even before. Any suggestions? :seeya
[Modified by NoWorries, 6:53 PM 9/28/2002]
I dropped the right side, showing about 29 mm fender/wheel gap, the left is at 49 mm. Any idea how to even this up?
I'm going to get the rear adjusted/alligned to about 0.5 or less degrees camber on both tires.
:cheers:
I'm going to have to get it alligned, because of this crazy camber(I could take it around Talladega the way it is). One of my tie-rod ends is going out, I've been pumping it full of grease often, and it hasn't gotten any worse, but if I'm going to get the whole car alligned, I'm going to replace that before I take it in.
Still...I should be able to get the car back where it was, nothing else changed...that I know of.
BIG JIM
Is your driveway level?
Are your front wheels straight?
Otherwise I have similar setup on my 96 (rear fender gaps are different). I decided to leave the adjustments the same side to side and deal with the gaps.
You could always have it corner weighted???
