climate control problem
Old May 25, 2017 | 07:21 AM
max76's Avatar
max76
Default climate control problem
Hi guys,
i recently change my blower control module.
Now the problem with the fan Always on is fixed.
I have a new little (i hope) problem with the climate control.
if i push on the botton for change air flow the light on the botton came on, but the flow don't change, it's seems that is block in defrost position.
Did anyone have the same problem?
What can i check?
Thanks in advance
Max
Old May 25, 2017 | 03:54 PM
Space's Avatar
Space
1st Gear
Default Climate control
Pull control unit out check all vac lines all the settings are vacuum controlled
Old May 26, 2017 | 01:10 AM
Cliff Harris's Avatar
Cliff Harris
What year is the car?
The vent doors and the air flow are controlled by the HVAC programmer. It's attached to the inner firewall above the accelerator pedal.
To climate control problem
