88 front brake identification
Old May 25, 2017 | 11:09 AM
tybotim's Avatar
tybotim
Default 88 front brake identification
I have front suspension off 88. How do I tell HD brakes from non HD brakes? TIA
Old May 25, 2017 | 11:34 AM
c4cruiser's Avatar
c4cruiser
The heavy-duty brakes will have 13" rotors. Standard brakes use a 11.5" front rotor.
Old May 25, 2017 | 01:22 PM
Ralph88's Avatar
Ralph88
If I remember correctly, only cars with the Z51 handling package had the HD brakes in 1988. The base model and Z52 package which mine is, had the 11.5 front rotor, but I am not 100%. Also not sure if yours are original equipment or aftermarket.
Old May 26, 2017 | 01:13 AM
Cliff Harris's Avatar
Cliff Harris
The HD brakes have 2 piston calipers. The standard brakes have single piston calipers.
Old May 26, 2017 | 03:37 AM
WVZR-1's Avatar
WVZR-1
NO!
'84 thru '87 single piston
'88+ all are 2 piston fronts and they're the same size piston. The pads are the same. Caliper "throat" is increased for rotor thickness and the bracket/abutment is different to accommodate the larger diameter.
In '88 HD brakes were included with FE7 - No FE7 there wouldn't have been larger brakes unless added.
In '89 JL9 and J55 became brake RPO options.
To 88 front brake identification
