Diagnose this???
Old Sep 29, 2002 | 08:05 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Diagnose this? IT WAS definitely the OPTI..
I just got off the highway, and the car started running real choppy (real rich). I put new plugs in, checked injectors for operation (good), all spark plug wires working, no codes (EGR electronically shut off via chip).
Ran DIACOM, barely idles, but have data if interested. It is actiing like it is in LIMP mode, but with no codes.
Motor has less than 1000 miles, OPTI is a 95 unit, HOT CAM, 396, ED Wright chip, plugs blacker than doo-doo (dry black), tried 2 different ignitions(factory and MSD), no mechanical noises, it is just msiing real bad. Please help if you can. Steve
[Modified by steve40th, 7:26 PM 9/29/2002]
[Modified by steve40th, 5:36 PM 10/1/2002]
Old Sep 29, 2002 | 08:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Diagnose this??? (steve40th)
Look at your O2 sensor(s) and see if it/they are laying flat (likely low), with no oscillation between .3V & .9V.
Also see if it shows loop status as closed loop mode.
don hall's Avatar
don hall
Damn, Steve. If you didn't have a new opti, that would be my first guess as the source of your problem. Without DTC's, a diagnosis is very difficult, especially with all the corrective measures you have taken. I have a '93 GM manual for reference, if you don't.
(Served a year at the Navy radio station, Wahiawa, many years ago)
Old Sep 29, 2002 | 09:25 PM
steve40th's Avatar
steve40th
Default Re: Diagnose this??? (Oldman)
I checked the O2's and already replaced them. I have the data, but I cant read on my computer, excel is gone, but on Diacom the O2's were around 450mv.
I am thinking OPTI. It was stored sionce May, and only driven 3 times. It drove fine, even made arun down the track last night. I walked it out then hit in 3rd, 13.2 114mph. Ran good, till I got off the Hoghway. FP is at 42psi, without vacuum.
I am at a loss. Injectors were at 3.5 (30# SVO's) and BLM was 128, INT wat 110 all at idle.
[Modified by steve40th, 3:45 PM 9/29/2002]
Old Sep 29, 2002 | 11:27 PM
steve40th's Avatar
steve40th
ttt, opti?
Old Sep 30, 2002 | 07:29 PM
steve40th's Avatar
steve40th
I am replacing th e OPTI and Water pump, under warranty anyways, parts at least. If that doesnt fix this....
Old Sep 30, 2002 | 07:51 PM
ittlfly's Avatar
ittlfly
What was the intergrator readings? Did the FP drop when you hooked up the vacuum line at idle? Check the EECS system, especially the soleniod to see if it's cycling the canister rather than stuck open. Injector resistance within 1 OHM of each other? Just some thoughts.
Old Sep 30, 2002 | 07:58 PM
steve40th's Avatar
steve40th
Default Re: Diagnose this??? (ittlfly)
The integreator readings were 110, BLM 128. This was after it was warmed up. SO the motor was still Hot. I dont have th einjector resistance, but I have the DIACOM file showing the engine at idle, if you would like it.
Old Sep 30, 2002 | 10:39 PM
ittlfly's Avatar
ittlfly
It sounds like a fuel problem. You might ohm out all your injectors to see if they are within 1 ohm of each other.(possible shorted injector soleniod problem). Did you check the EECS soleniod for sticking open? That would continously purge your canister vapors into the intake enriching the mixture. With the intergrator at 110 and the blms at 128, shows a short term correction going on with the system in control. also check the voltage out of the alternator. That will raise hvoc with the ECM if not within specs. And lastly, the fuel pump...???
BTW, we're headed for "The Big Island" tomorrow morning for aweek....so aloha ,and hope you get the problem resolved :seeya
[Modified by ittlfly, 6:42 PM 9/30/2002]
Old Sep 30, 2002 | 10:42 PM
BBA's Avatar
BBA
Default Re: Everything points to the opti, but why so fast? (steve40th)
If you have a MAF...that could be it, if not, the second guess would be TPS ( mine did that when it went bad ).
Old Oct 1, 2002 | 12:29 AM
steve40th's Avatar
steve40th
Default Re: Everything points to the opti, but why so fast? (BBA)
"It sounds like a fuel problem. You might ohm out all your injectors to see if they are within 1 ohm of each other.(possible shorted injector soleniod problem). Did you check the EECS soleniod for sticking open? That would continously purge your canister vapors into the intake enriching the mixture. With the intergrator at 110 and the blms at 128, shows a short term correction going on with the system in control. also check the voltage out of the alternator. That will raise hvoc with the ECM if not within specs. And lastly, the fuel pump...???"
The EECS solenoid? How do I check that? I also disconnected the injectors one at a time and no change. But how else can I check the injectors with a volt meter?
Fuel Pump is a GM "Grand National" unit about 1 1/2 old.
Old Oct 1, 2002 | 11:39 PM
steve40th's Avatar
steve40th
I took the OPTI out , and when I spun it the noise was definitely not good.
It rattled and I could here pieces moving around that werent attached to anything. So hopefully, When the new one comes tommorow, and I replace it, I hope it fixes it. Thanks for all the help, Steve
To Diagnose this???
