Turn Key to run, Cooling fan on, headlights open and on
1994 C4, When I Turn the Key to run position, Cooling fan comes on, when car is cold,
Any ideas?
Any ideas?
You removed your reference to HL open and on so I assume you sorted that.
I think the HL are working the way they were designed?, No flashing lights on the climate control unit after 5 seconds.
Do you know how to pull codes using the on board diagnostics and ALDL connector? Your probably looking for codes in module 4.
