Fuel solenoid keeps blowing
Fuel solenoid keeps blowing. The car has been sitting for about five years bought it from original owner yesterday car keeps blowing fuel solenoid. I believe it would be the fuel filter as your pressure is fine. Any ideas? I don't to search and the only thing I keep coming up with is where is the fuel solenoid.
It's a 92. They keep sticking closed. So energized. What do you take it apart after it's failed the magnet is staying closed. I don't know what would make the car keep making them fail. It's happened 3 times in 2 days. Once it failed i replaces car starts right up before replacement The car will cranking cranking crank you have spark but it won't fire unless you put gas down intake itself . But like I said the second you replace the relay The car fires right up. Then once it fails you could take the really a part and it's stuck closed.
I don't think we know what the problem is!
Can you show us a picture of the relay that's causing your problem?
Ok I am sorry. Long story short I had 2 that will not engage on that had stuck engaged. My guess is all three where bad for there own issues. I have a new one in car now. The others I had from other cars. They where good when I took them out but....... So I'm a moron that should have just got a new one from the start!!! If it happens again I'll let you know.
