Windshield wipers won't quit running.
Old Sep 29, 2002 | 08:48 PM
vette92_1's Avatar
vette92_1
Default Windshield wipers won't quit running.
When I turn on my windshield wipers they work fine in all modes, delay, slow, fast, but when you turn them back to the "off" position they will keep running as if they are in the "slow" position. Sometimes they will keep going for about 10 - 20 swipes before they will finally stop. I thought it might be a short, which it still could be, however wiggling the wiper control on the turn signal arm doesn't seem to effect it one way or the other.
If it is the switch, is the turn signal switch and the wiper switch all in one?
:confused:
Old Sep 29, 2002 | 10:32 PM
BBA's Avatar
BBA
Default Re: Windshield wipers won't quit running. (vette92_1)
It's not the switch. The switch is not like the old style where turning it off removes power from the motor...nope, it only pulses a signal.
Mine does the same thing. The electronic control part of it is built into the wiper motor assembly. Thats what goes bad...and usually the whole motor is worn out as well. Very few people have had luck just changing the electronic part of the motor, which, by the way, you can get seperately, ...they usually end up replacing the whole thing.
Old Sep 30, 2002 | 02:47 AM
BlackbirdZ07's Avatar
BlackbirdZ07
Default Re: Windshield wipers won't quit running. (BBA)
Mine was doing funny things, and the problem turned out to be the park switch INSIDE the motor. It is available separately, and was easy to install. It could be that that switch is bad, or it could be the a problem in the circuit board in the motor cover. The motor cover is also available separately and is even easier to install, but costs more.
I just looked up your problem in the factory manual. It has a table of windshield wiper problems and the most likely cause for each. Under "Wiper won't shut OFF" it lists the most probable cause as a faulty park switch. I got mine from The Last Detail (www.tld-corvette.com or 770-414-0077) for $37. They don't list the part in their catalog but they did have it in stock. I'd start by replacing that, I bet it'll fix the problem.
Old Sep 30, 2002 | 03:22 AM
84Coyote's Avatar
84Coyote
Default Re: Windshield wipers won't quit running. (BlackbirdZ07)
Mine did that when I got it wet. The circuit board got wet. I dried it out with a hair dryer and over time it got better. You may need to replace the whole assembly though
Old Sep 30, 2002 | 07:05 AM
vette92_1's Avatar
vette92_1
Thanks everybody for the comments. I will replace the park switch and see what happens. I looked it up in my manual as well, and just like you said, that is the only thing listed as a "probable cause" for what its doing.
Thanks again :seeya
[Modified by vette92_1, 5:07 AM 9/30/2002]
Old Sep 30, 2002 | 08:32 AM
BBA's Avatar
BBA
Hey...if that works, let us know. I might need one as well.
Old Sep 30, 2002 | 09:48 AM
92TripleBlack's Avatar
92TripleBlack
Pull the fuse until you get it fixed. You can put it in if it rains but if you let the wipers run on a dry windshield you may get scratches.
Old Oct 1, 2002 | 09:34 PM
vette92_1's Avatar
vette92_1
Ordered part today.
Old Oct 4, 2002 | 11:03 PM
vette92_1's Avatar
vette92_1
Just got the new park switch today. I installed it in approx. 30 mins time, fairly easy job. Wipers work perfect.
Thanks to all... :cheers:
Old Oct 5, 2002 | 12:45 AM
BlackbirdZ07
Cool. :cheers:
Old Oct 6, 2002 | 02:11 PM
vette92_1's Avatar
vette92_1
Thanks BlackbirdZ07 for the "The Last Detail" info. That is where I purchased the park switch. Friendly, helpful and good price with quick shipment, I was very happy. :yesnod:
Old Jul 21, 2011 | 01:38 PM
quickspit's Avatar
quickspit
7th Gear
What fuse is it? I can not seem to find the one for the wipers.
To Windshield wipers won't quit running.
