code reader tool
Old May 30, 2017 | 11:23 PM
Max Dever Pierce's Avatar
Max Dever Pierce
Default code reader tool
I am going to need a code reader scanner tool for a 1993 corvette, Summit has some that are for 1996 & newer. Dose anyone know a good one?
Old May 30, 2017 | 11:52 PM
ChumpVette's Avatar
ChumpVette
GM Tech 1 or GM Tech 2
Old May 31, 2017 | 08:23 AM
hcbph's Avatar
hcbph
I picked up an Innova the other year that reads both ODB1 & ODB2 vehicles off Amazon. Can't swear to it as I'm not home but I think the model number is 3140 but would have to check to be sure. I've used it to read and reset codes on ODB1 & 2 vehicles I own and it's worked every time.
One advantage of one like this is I own the Vette, a T-Bird, a Caravan and a F150 and it works on all of them.
Whatever you look at, read the specs over closely and insure it does what you're wanting. There are a lot of units out there and not every one does the same things.
Hope this helps.
Old May 31, 2017 | 09:45 AM
ss95003's Avatar
ss95003
amazon has wifi/ boothtooth readers that connect to your phone/ pad for less then $20 and there are $10 apps that can do everything expect tunning.
Old May 31, 2017 | 01:49 PM
jerrspud's Avatar
jerrspud
Torque app is free. That's what I use. Just a simple code reader.
Old May 31, 2017 | 10:28 PM
aklim's Avatar
aklim
MT2500 is another good one. NFW would I get a code reader. Too much money for too little.
Old Jun 1, 2017 | 09:34 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
What about OBD1?
To code reader tool
