1989 with auto. Stock
I put vacuum tester on the large vacuum line running from servo to brake pedal dump switch. It will not hold vacuum. I just replaced switch, but it appears vacuum line is leaking. Anyone replace it and how hard is it. Looking for tricks to make it easier
Mike
It is a Generic Hose unless you feel it totally necessary you could just pick up a section of hose a use a splice where needed, if I remember correctly it is not Impossible just a bit of a Knuckle Cutter.
