Change Your Fuel Filter Lately?
Old 06-05-2017, 02:48 PM
DGXR
DGXR's Avatar
WOW that is some serious gunk! Glad to hear of your positive results after replacing it.
Mine starts quickly and runs great, plus the filter is super shiny compared to the rest of the hard parts so I think a previous owner changed it. I'll check the receipts/records that came with the car, to be sure. The car has 66,000 miles.
Old 06-05-2017, 02:55 PM
81c3
81c3's Avatar
Mine was a Fram, so I know it was changed at least once. Im guessing it was changed when the fuel pump was replaced about 12-13 years back.... that would be the time to do it in my opinion... but this is all 2nd hand knowledge. The previous owner had the car for a few years, but his father had it most of its life and he did the pump.... thats the story I have... so I have to roll with it.
Old 06-05-2017, 03:17 PM
don hall
don hall's Avatar
Besides rust in the fuel tank, it is possible to have rust form in the fuel lines...... changing pump and sock may not solve the problem, if the lines are rusty (?).
Old 06-05-2017, 04:29 PM
81c3
81c3's Avatar
I would suspect if there was rust inside the fuel lines, I might see it outside on the surface of any metal parts on the underside also.... there is none what so ever... Im just going to have to hope for the best I suppose. Once I pull the sending unit and look at it, and inside the tank, maybe Ill get a better perspective. Anyway, its not all rust in the pic... a lot of it is almost like a very fine sand or something...
Old 06-05-2017, 04:36 PM
don hall
don hall's Avatar
Originally Posted by 81c3
I would suspect if there was rust inside the fuel lines, I might see it outside on the surface of any metal parts on the underside also.... :
Not necessarily, could rust inside without outside evidence.
Old 06-05-2017, 04:47 PM
81c3
81c3's Avatar
How would the fuel lines rust in a sealed system with fuel inside them and no air to cause the corrosion? I'm not really too concerned with the fuel lines rusting inside. The car was garaged its entire existence. The fuel filter had no rust at the inlet in the line. I actually would never had known of all that gunk if I didn't bang the filter on the shop table and seen it come out. It'll be fine...
Old 06-05-2017, 05:10 PM
don hall
don hall's Avatar
How would the fuel lines rust in a sealed system with fuel inside them and no air to cause the corrosion? .......
If there was water/moisture in the fuel, it could rust the fuel line internally, especially in storage.
Old 06-05-2017, 05:18 PM
81c3
81c3's Avatar
Well, at this point... Like I said, I think Ill be ok. Have to see how it goes... Car was running great.... this is all precautionary anyhow. Only time will tell. In about 6 months Ill pull the filter and check it to see how it looks. Thats about all I can do... Thanks for your input!
Old 06-05-2017, 07:19 PM
81c3
81c3's Avatar
Originally Posted by ihatebarkingdogs
I don't think it's Iron Oxide. ("Rust"). Wrong color. It is also a large size grain of fairly regular size. Rust flakes are much more random. That's why it still ran, the element didn't get plugged with finer sediment, those big grains could still pass fuel between them. I see specks of orange which could be RTV from an earlier repair. Because the in-tank strainer had to have failed in order to pass these grains, I'm thinking the granules may be the remnants of the strainer screen. Another possibility is that the incorrect style of hose was used during previous pump exchanges, and the grains are hose debris. But this is less likely as A: When the hose burst, it wouldn't run, B: The strainer still had to fail to pass the grains.
I think it's the strainer.
When you figure out what that gunk is, please revive this thread and post back. I'm curious as to what it turns out to be.
I surely will. The pump/sender unit is on its way. Will I be able to see well into the tank with a flash light? I haven't done this job yet... so not sue what exactly to expect in that regard.
Old 06-05-2017, 08:09 PM
jpipx
jpipx's Avatar
Default Great motivation for me
I went online and ordered some fuel filters right after seeing your picture.
Great motivator!
Old 06-05-2017, 11:36 PM
woodstockdrifter
woodstockdrifter's Avatar
Whats the recommended mileage interval to do this? thanks
Old 06-05-2017, 11:46 PM
A Peter C4
A Peter C4's Avatar
My 94 coupe owners manual says, Periodic replacement of the fuel filter is not required. My self I would think 100,000 miles this should be done. My car has 105,000 And I do not think anyone has changed it, no records with car, I will have to check and see if it has original filter. I have a new one and will change it regardless.
Old 06-06-2017, 09:31 AM
  #33
Cjunkie
Cjunkie's Avatar
If there is an inline fuel filter from the factory (no in tank non serviceable) 20-30k tops it should be replaced.
A Peter C4 (06-06-2017)
Old 06-06-2017, 04:42 PM
  #34
DMITTZ
DMITTZ's Avatar
Since it only costs a few bucks and only takes a few min I usually change my fuel filter yearly. Since mine is in storage for the winter I also generally drain the tank out when I change it to be safe. But that is proabbly way overkill.
Old 06-06-2017, 04:59 PM
  #35
A Peter C4
A Peter C4's Avatar
I do not have any fuel problems at the present time but I think it would be good idea to replace with new with 105,000 on it.
Old 06-06-2017, 06:11 PM
  #36
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
Ya Think!!!
Old 06-08-2017, 10:20 PM
  #37
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Originally Posted by phil48315
Hmm my 92 has the original filter !
But it also has 20 yr old gas in it !
Are you bragging ?!
To Change Your Fuel Filter Lately?
Old 06-09-2017, 01:51 AM
  #38
phil48315
phil48315's Avatar
2017 C3 of Year Finalist
Originally Posted by JrRifleCoach
Are you bragging ?!
Nope just stating facts.
I just found a 92 that has been parked in the garage since the original battery died 20 yrs ago....(20k miles)
Was in the process of bringing it home when my Brother passed away unexpectedly.
So I have been out in Az. for the funeral and to spend some time with my parents for the last 10 days.
Flying home to Detriot in the morning, and plan on picking it up later in the week.
Old 06-09-2017, 03:04 AM
  #39
JrRifleCoach
In that case I'd drain as much of that varnish as possible before powering up the fuel pump. Theres a bunch of other fuel related parts that should be replaced as well. But a good fuel flush should get 'er going.
Sad to hear about your brother.
phil48315 (06-09-2017)
Old 06-10-2017, 05:05 PM
  #40
81c3
81c3's Avatar
Default Results of Fuel Pump Swap
So heres what I found.... obviously Bubba Gumps Corvette Shop installed the pump 12 years ago without a damn pick up strainer!!! I looked inside with a flashlight and theres no sign of it.
So the positives of the swap are:
1.It was very easy with the exception of the return line rubber hose connection. That was a PITA because it was old and brittle.It did NOT want to come off!! I wound up cutting back a 1/2" or so to get to a better section of hose for the attachment.
2. There is sediment in the tank, but nothing I would call excessive for a 31 year car.
3. I noticed the pump is much quieter
4. The engine starts quickly EVEN when hot now!! (it would take a lot longer before after the first start of the day)
5.Throttle response seems just a bit better now
One negative:
When I come to a stop and get out, engine running,I get a whiff of fuel smell from under the hood now that I didnt notice before. I dont see any leaks of any kind under the hood at the filter or back by the pump/sender. I even pulled the fuel door back off and rechecked to see if there were any signs of wet fuel.... nothing, bone dry. I dunno... Other than that, everything is improved drive-ability wise.
Im pretty sure Bubba didnt have the paperwork that came with the Ecklers unit....
Quick Reply: Change Your Fuel Filter Lately?
