1.It was very easy with the exception of the return line rubber hose connection. That was a PITA because it was old and brittle.It did NOT want to come off!! I wound up cutting back a 1/2" or so to get to a better section of hose for the attachment.
I'd be leery as to what hose was used between the pump and the metal tubes. If it is not the right hose, it will leak sooner or later.
Seemed to be fuel line. I checked after about a 35 mile test run and no leaks. It cant be the wrong type of hose because the other end of it is a factory crimp connection ie, no clamps of any sort. Im 100% sure its a factory piece.
Usually that hose is replaced with hose that is RATED for fuel IMMERSION. I don't fully understand what happens if the hose is not rated but some have said it eventually leaks. As to the fuel system, I'd check it for internal leaks like the check valve in the pump (if it has one) or somewhere else.
I dont think the hose would ever be immersed in fuel. Its on the top of the tank (outside) of it. Like I said, its a factory part and the one end is much like a PS pump hose crimp fitting, which is crimped to the hard fuel line. Its just 31 years old and the end where the hose clamps to the steel nipple was hard and taken form over the barbed portion of the nipple. Thats what made it hard to push/pull off.
I was thinking about the fuel smell yesterday... it was like 100 degrees here. Maybe just the full tank of gas combined with the emissions evap canister it was more noticeable. I think everything is ok. Im just always paranoid after a repair....
I was talking about the hose between the pump and the tube rather replaced the pulsator.
Its a 100% brand new unit... not just the pump... The entire unit, from the filler neck to the pick up screen.
Perhaps but at this time, I do not know if it has a pulsator that came loose or a fuel rated hose. Also we do not have a direction to look at with respect to where the leak is around.
You lost me man... I have no leak. Its all good. The car is running better than ever and there are no problems currently with any part of the unit.
The hose INSIDE the tank has to be special hose for immersion. All modern fuel hose has a plasticized liner inside the hose. You can see it, and pick the liner with your fingernail. Immersion hose has the liner on the outside as well. If the hose deteriorates from the outside-in because its the wrong type, the pressure blows it out. The engine quits running because there is no fuel pressure.
I'm wondering if the debris in your filter is the foam anti-noise sleeve on the old pump?
For gas fumes in the engine compartment with no obvious leaks, inspect all the evaporative canister hoses carefully for deterioration, and for being attached to the engine.
So the small 3" long fuel hose that comes with the new unit is what you're talking about.... I am assuming that the manufacturer would assemble the unit with the correct hose wouldn't they?
I'm not sure on the debris... this is the 3rd pump the car has had in its life. I don't know what the PO or shop found... I really didn't find anything that pointed to what was in the filter.
If so, I agree. I got your issue confused with another case where we were seeing a huge drop
I thought I was starting to go completely stupid.... Thanks for clarifying!!
Doesn't rule that or insanity out. Of course, we could also be part of someone's dream or part of a video game but not know. Possibilities are endless.
Im hearing the Twilight Zone intro song playing in my head..... or is it?
