DISREGARD THIS POST (unless used for checking and double checking your work or a similar issue, problem has been solved)I wanna make this short and sweet. Pretty much whenever I turn the steering wheel left or right, about half way either way, the car bogs slightly and all my instrument clusters light flash on and off until I move the wheel again. Whenever the lights do flicker I hear the spark of wires crossing. If I leave it there long enough the car will just shut off. I had this issue two times before which both times caused fires. The first time it burned the steering column to the ground, nothing else was damaged. The second time I caught the symptoms and was able to prevent it from being a huge fire. The second time it happened I replaced the turn signal switch/multifunction which had fixed the issue for half a year. But then the car sat for a while and I have to drive it again and the issue is back. Any ideas on where to look at this point? Headlight switch and ignition switch are new. I don't see any wires crossing when I turn the wheel but I can't really see inside the column. I'm going to disconnect the horn fuse and see if the horn contacts aren't playing tricks on me.
PLEASE DISREGARD THIS POST(unless used for checking and double checking your work)
i just found the culprit. My power wires run over the steering knuckle/column in the engine compartment. The wires are stripped and exposed but would only make contact when it turned a certain amount to the left or right. The power wire was grounding right off the column.
