How to replace the ignition switch in a (c4) 1985 corvette
I now believe that the ignition switch must be replaced from below, although the switch is on top, removing the dash pad does not give access to the switch because of AC venting.
I have also read that "Dropping" the steering wheel / column will help however I have no idea how to do that.
Has anyone seen a step by step with )or maybe even without) pictures of an on car service of the ignition switch of a C4 corvette?
http://www.autozone.com/interior/ign...r/12471_0_7120
http://www.autozone.com/batteries-st...eVehicle=false
The Switch (under Dash Top of Column) is a bit of a Knuckle cutter. First Disconnect the Battery, Some of the car's Big Voltage comes to this point so Error to the safe.
You will need a 1/4 Drive socket set maybe some of the smaller wrenches. (Dropping/Dipping the Steering Column down may be needed to get access)
Disconnect the wire unbolt from Column remove. The replacement should come with a Little pull tab on it the instructions will tell you which position to have your Cylinder in I believe it should be the park/key out position. put switch on aligning the switch rod and Snug down remove the little tab. Connect the wires, Test if all is good finish the assembly DONE
