3 wire oxygen sensor
Old Jun 8, 2017 | 07:33 PM
lotuselan1964's Avatar
lotuselan1964
2nd Gear
Default 3 wire oxygen sensor
where is the best place to get power for a heated oxygen sensor on my 1987 corvette.
Old Jun 8, 2017 | 11:09 PM
Hive's Avatar
Hive
Following, doing the same on my 93. Do these sensors always run the heater from +12v? or should they be controlled by something?
I thought just wire it into the ignition-on circuit, fuse and relay it from there.
Old Jun 10, 2017 | 12:17 AM
aklim's Avatar
aklim
I would hate to tap into the fuel injectors just because they are a critical item. Maybe use something simple that does NOT throw a code like the AIR system? Those are switched.
Old Jun 10, 2017 | 12:52 AM
IHBD's Avatar
IHBD
Pro Mechanic
Tapping into the injector HOT side will NOT "throw a code". Matter of fact there are NO codes associated with the injector circuits. NONE. What code does a shorted multec injector throw? Huh?
The A.I.R. circuits are the same as the EGR solenoid, which was my first suggestion. Probably better than the injector hot, but the injector hot is easier to find, and will work just fine.
Old Jun 10, 2017 | 07:29 AM
9T3VETTE's Avatar
9T3VETTE
Do a search but I tapped into the fan relay blue wire (I think) which is near the radiator. It's switched 12v That I ran to a relay with constant 12v power coming from the positive hub behind the battery. Also used an inline fuse for added protection.
Old Jun 10, 2017 | 08:01 AM
Dt86's Avatar
Dt86
I just used a Fuse tap off the dash circuit(5a key on), ran a wire through the dash, and out the driver side grommet. I bought a weatherpack connector to hook it up.
To 3 wire oxygen sensor
