over heating
Old Sep 30, 2002 | 02:59 PM
atotalnincompoop's Avatar
atotalnincompoop
Default over heating
i'm having a problem with overheating, i have by-passed the throttle body by running one heater hose directly to the front of the intake and the other directly to the water pump. i am running vortec heads and a scoggin-dickey intake manifold for tpi. i realize that the anwser is something very obvious, i'm stumped right now, i think that i have been looking at it too long :cheers:
Old Sep 30, 2002 | 03:02 PM
vader86's Avatar
vader86
Default Re: over heating (atotalnincompoop)
What are your temps? coolant and oil.
That Temp tstat are you running, how long has it been since you cleaned the front of your radiator.
Old Sep 30, 2002 | 03:05 PM
atotalnincompoop
Default Re: over heating (vader86)
i'm running a 160* stat and the rad is very clean, the problem is there even when i remove the thermostat. i flushed water through the heater core to eliminate an air lock, it runs for a few minutes and then i get the vulcano out the rad cap
Old Sep 30, 2002 | 03:07 PM
atotalnincompoop
as far as the temps go, i don't have the number in front of me right now and i was out of town for a week but i think that they were above the boiling point for water, the oil i don't remember
Old Sep 30, 2002 | 03:10 PM
C4-Wolf's Avatar
C4-Wolf
Possibly a bad coolant pump? Does the upper radiator hose get hot when running the car? If not your probably not pushing any coolant through it.
Old Sep 30, 2002 | 03:15 PM
vader86's Avatar
vader86
Sounds like you may have a bad water pump.
atotalnincompoop
Default Re: over heating (C4-Wolf)
i'll go check that this evening, i think you may be correct. thanks i'l get back to you, my biggest fear was that it was something to do with the heads and that i possibly used the wrong head gasket and blocked off a water passage, does anything like that sound familiar :cheers:
Old Sep 30, 2002 | 03:25 PM
vettmech's Avatar
vettmech
What engine is this?.........as far as water pumps...... they will pump and pump......... the only thing they do wrong is leak or the bearing will go out. The metal impeller will keep pumping though. I ask what engine because as you said it could be heads or a passage........like a 400 block with 350 heads ........ya have to drill the steam holes in the heads..........need more info :seeya
Old Sep 30, 2002 | 03:44 PM
64FITanker's Avatar
64FITanker
Default Re: over heating (vettmech)
Had this problem in my '85 (oflow tank puking out all the coolant). 2 things fixed it. Gasket was bad in the oflow tank cap, and the radiator cap was bad. Fixed the cap, and got the correct 17lb cap from the general. Voila, problem gone. And it gets tested a lot here in Vegas.
:mad :flag
Old Sep 30, 2002 | 05:39 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
The pressurized coolant in the engine won't boil until over 250* F, it will lower to around 220 (50% H2O) if the system does not hold pressure. Is the cap any good, does it seal, do you have coolant leaks?
If you are blowing coolant out the cap in only a few minutes of running (does the fan come on?) you have issues. I would pressure check the cooling system and perhaps run a compression check. How does the oil look?
It's quite normal for these engines to run over 220*.
Old Sep 30, 2002 | 06:21 PM
atotalnincompoop
Default Re: over heating (PeteL)
its a 350 block ( '85) with '98 350 vortec heads, it boils over with the system unpressurized( no cap on) . does anyone know if the water passages all line up, i have never read anything about them not, but i suspect that this may have something to do with it :cheers:
Old Sep 30, 2002 | 06:24 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
if it just happen after the swap you might have an allighnment problem with the head and or intake
Old Sep 30, 2002 | 06:26 PM
atotalnincompoop
Default Re: over heating (CORKVETTE1)
well i purchased an intake that is cast specifically for a tpi/vortec application. is this the misalignment your referring to? :cheers:
Old Sep 30, 2002 | 07:15 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
is the heads a match for that intake? :cheers:
Old Sep 30, 2002 | 07:21 PM
atotalnincompoop
it is supposed to be, it was the scoggin/dickey intake made for this application :cheers:
Old Sep 30, 2002 | 08:41 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I may be all wet, but how did you do the throttle body by pass?
I've done mine and never chasnged the direction or connection of the heater hoses, just put a nipple in to connect the inlet and outlet hoses from the throttlebody.
Like I said, I may be all wet, but i would look again at the heater hose set up
Jack
Old Sep 30, 2002 | 11:51 PM
atotalnincompoop
Default Re: over heating (jackdaroofer)
well, i think that i have that right, the hose from the upper heater hose connection runs to the intake and the lower cinnection to the water pump. i put new hoses the proper length on instead of splicing together the old ones. do you think that i have something backwards here? :confused:
To over heating
Old Oct 1, 2002 | 12:03 AM
don hall's Avatar
don hall
Let's hope none of these symptoms exist:
Is there pressure in the system when you remove the rad. cap with a cold engine?
Is the rad. low on coolant after cooling down?
Is the overflow bottle full with a cold engine?
Does your coolant "bubble" (not boil) with the rad. cap off, and the engine running?
If so, you may have a small exhaust head gasket leak into your coolant system.
[Modified by Oldman, 8:06 PM 9/30/2002]
[Modified by Oldman, 8:11 PM 9/30/2002]
Old Oct 1, 2002 | 12:06 AM
atotalnincompoop
Default Re: over heating (Oldman)
i will check this tomorrow, sounds like a possibility, thanks to everyone :cheers:
Old Oct 1, 2002 | 06:33 PM
atotalnincompoop
i'm starting to think that maybe i'm really stupid. i have made my own throttle body by-pass simply by routing a new piece of hose from the front of the intake to the heater core metal line. the other heater core metal line is then connected to the water pump. I'm sorry to have to ask this but is this routing correct? i obviously have some sort of coolant flow problem which may still be an air lock. i'm just wondering if i have something hooked up backwards which is causing all of my problems. thanks again guys :cheers:
