96 Corvette LT1 AC Leak
If not, is this something that I can replace on my own and then take in to get the system evacuated and charged? Or can I replace it and just charge it on my own? Is it a difficult job to do or should I just take it in and have them replace the part?
Thanks for any advice on this.
I will toss some soapy water on it tonight and verify that there is a leak there but I felt it with my hand and heard it so I am certain that there is a leak there.
Most leaks cannot be heard but if you can actually hear it, it's a monster leak.
Replacing the evaporator is a big job that requires special tools and a knowledge of A/C building the system back where you can add Freon.
Unless you have a leak detector or have dye in the system and have viewed it with a UV light, you really don’t know where the leak is.
I suggest you go to a good A/C shop and get a free estimate of what the problem is and then you're have real data and a direction of what to do next.
If the evaporator was bad, you could replace and then have a shop evacuate and charge it. But they won't guarantee the work you did or the part.
