Taylor wire and wire retainer
Old Jun 12, 2017 | 01:47 PM
Christi@n's Avatar
Christi@n
Default Taylor wire and wire retainer
I've replaced left side spark plug wire Taylor spyro pro 8mm in place of stock, though wire retainer are too small, any idea?
Old Jun 12, 2017 | 02:47 PM
bill mcdonald's Avatar
bill mcdonald
After modding my car, I have not used wire retainers at all.
I did buy a set from summit that bolt to the top of the valve covers, but they were for center bolt valve covers. I removed them after constantly working on the car and they were always a hassle.
I cannot remember the stock set up for the life of me. It is not something you can just drill out?
Old Jun 12, 2017 | 03:02 PM
Joe C's Avatar
Joe C
what kind of retainers? stock, aftermarket, ??? I've used taylor 8mm wires with stock retainers without issues.
Old Jun 12, 2017 | 03:12 PM
Christi@n's Avatar
Christi@n
Are stock retainers with Taylor wires
Old Jun 12, 2017 | 03:16 PM
Joe C's Avatar
Joe C
??? - can't understand why you would be having a problem. can you post a pic?
Old Jun 12, 2017 | 03:31 PM
Christi@n's Avatar
Christi@n
it is not necessary to drill out them, are the stock type with four holes and retainer clip... Just need to pull the off, and put on something with bigger holes
Old Jun 12, 2017 | 03:33 PM
Joe C's Avatar
Joe C
OK, we're talking apples and oranges here. just realized you have a 95 LT1 car - everything I've done has been with earlier L98 cars.
since I do not have any experience with late model C4's, probably can't help you. sorry....
Old Jun 12, 2017 | 03:35 PM
Christi@n's Avatar
Christi@n
wires are too big, and retaining clip is slightly squeezing them
Old Jun 12, 2017 | 04:47 PM
Joe C's Avatar
Joe C
what's the diameter of the stock wires?
Old Jun 12, 2017 | 09:20 PM
A Peter C4's Avatar
A Peter C4
Stock ACDelco are 7mm.
Old Jun 13, 2017 | 12:54 AM
STL94LT1's Avatar
STL94LT1
Dremel the holes a little larger, worked on my 94.
Old Jun 13, 2017 | 04:49 AM
Christi@n's Avatar
Christi@n
Isn't any type of bigger retainer on the market to use with these 8mm spark plug wires?
Dremel the holes is a nice idea, but i don't feel like it... I Would replace them...
Old Jun 13, 2017 | 05:53 AM
Joe C's Avatar
Joe C
googled "8mm spark plug wire retainer" (images) - gives an idea of what's available...
https://www.google.com/search?https:...=1497347450765
Old Jun 13, 2017 | 06:48 AM
Christi@n's Avatar
Christi@n
There's a lot of things about it.. I Think and hope I will find something that will match nice my car
Old Jun 13, 2017 | 08:11 PM
A Peter C4's Avatar
A Peter C4
I doubt you will find any that fit the stock brackets, but good luck.
Old Jun 14, 2017 | 04:37 AM
Christi@n's Avatar
Christi@n
So what 's your tip about it? Run with stock or run without?
Old Jun 14, 2017 | 07:43 AM
Tod Stiles's Avatar
Tod Stiles
Dorman stock style 8mm retainers. Work with the stock mounting tabs.
http://www.dormanproducts.com/itemde...9&SEName=40295
Old Jun 14, 2017 | 09:27 AM
Christi@n's Avatar
Christi@n
Suspect these are for l98, application guide is for 83-91
i have a 95
To Taylor wire and wire retainer
