Instrument Cluster
Old Jun 13, 2017 | 05:44 PM
Stephenms's Avatar
Stephenms
Default Instrument Cluster
Hey guys just curious if anyone has had this particular or if you are aware of a way to fix it.
Basically my instrument cluster will not light up unless the car has been baking in the sun and it's hot inside. On cold mornings, nothing. When I get in the car at 6pm to go home, it's on and working. But if I go home at say 9, and the car had some time to cool off, it won't turn on. In the mornings I can still see all the numbers, it just isn't back-lit. So at night I have to shine a flash light on my dash every so often to see where my temps and speed are. The photocell/dimmer function was my first thought since holding a light to the photocell doesn't increase the brightness or dim, but I haven't poked around to replacing it. I used to be able to give the cluster a little smack and it would come back on, now it HAS to be warm in order to light up. Any ideas?
The cluster works fine other than that. I ripped the whole thing apart (except the LCD's) and had very minimal burn marks but just to be safe I was planning on switching to something less hot like the Xenon or LED bulbs. Batee does have a photocell kit for around 70 bucks, I'm just a hack job with soldering.
Old Jun 14, 2017 | 05:49 AM
hcbph's Avatar
hcbph
If it was mine, I'd send it to Batee and have Bryan take care of it. Had problems with mine the first year, sent it to Bryan and it's been fine ever since.
Old Jul 12, 2019 | 01:39 PM
97Chuck69's Avatar
97Chuck69
I sent mine to DINO's Corvette
Old Jul 12, 2019 | 01:51 PM
85WHITEZ51's Avatar
85WHITEZ51
If you tap on the dash will it turn on? It really sounds like a bad solder joint or the power supply going out. If you are comfortable soldering then I would buy a new power supply, and the backlight repair kit. If you are comfortable doing board work then just send it to them.
Old Jul 12, 2019 | 07:35 PM
hcbph's Avatar
hcbph
You realize the OP has had 2 years to do something with the instrument cluster. Additional sources for repairs are always beneficial.
Old Jul 12, 2019 | 10:22 PM
RetroGuy's Avatar
RetroGuy
https://www.taninautoelectronix.com/ Enough said
Old Jul 12, 2019 | 10:29 PM
WICKEDFRC's Avatar
WICKEDFRC
Get a new C8. Hehehe.
To Instrument Cluster
