What is R12a? Anyone using it?
Is it any good? Anyone use it?
I know the R134 is popular now, but the molecule is smaller and it can cause leaks in cases where R12 would not. (I'm told hoses can become permeable and such if they aren't tip, top perfect.)
Is there a downside to the R12a and maybe that is why I'm not hearing everyone talking about using it to replace R12?
Any help is welcome.. I'm lost on these things.
If your system was designed for R12, you can use it with no issue. If your system was designed for 134, then use that.
Some systems were originally R12 and then were converted to use 134. The conversions work reasonably well, bu not as good with the R12.
Someone mentioned one of these replacements being highly flammable. Is this the one? Is there a downside to it? Because all I see people doing with the old systems is converting them to 134, and often at considerable expense.
Why are they doing that if R12a is a direct replacement? Anyone?
R12 is just R12, not sure why the "a" is there.
R134A can be used however you will need the quick connect R134A fittings so everyone will know right away what refrigerant it has, they are cheap on ebay and screw right on to the standard R12 fittings.
R134A will need barrier type hoses, try your originals first they may be ok.
Empty all the oil from your compressor, replace with ESTER oil which is for R12 to R134A conversions. Good idea to replace all the rubber O rings To the new green / blue neoprene ones unless your system does not leak.
Replace the receiver drier, evacuate the system and charge to 80% of R12 charge with R134A.
Have done my 85 more than 10 years ago, no leaks all standard apart from new hoses and neoprene o rings.
She has nice cold a/c
Do you really want to risk your life or the lives of your passengers by using a cheap flammable refrigerant in your vehicle's air conditioning system? R-134a is the only refrigerant that should be used when recharging a late model automotive A/C system.
EPA SNAP Rules on Flammable Refrigerants
The US EPA SNAP regulations do NOT allow the use of flammable refrigerants in vehicles.
http://www.aa1car.com/library/flamma...frigerants.htm
Think I'll just do the R134 after all.
