door panel light gremlin...
Old Jun 20, 2017 | 05:35 PM
jsmcol's Avatar
jsmcol
Default door panel light gremlin...
Ok, so here's a strange one. Bought a 93 coupe in January. Got all the lights working, fuses replaced, etc. and while I was at it, replaced the door panel lights with LED, much brighter and uses less battery if door is open for awhile. LEDs worked great at that point.
Last weekend I took the passenger door panel off to lube the door lock latches, rods, etc since it was sticking. Went to put it all back together and the light no longer worked in just that panel. Driver still works fine.
I thought the bulb went bad, replaced it, still didn't work. Checked and it has 12 volts going to the bulb holder. I then put the original filament bulb in and it worked. Put the LED (tried three new ones) back in, none worked? Right now, I have the original filament bulb in there and it works.
Any suggestions? I can try swapping the drivers bulb which I know was working, but this is just mysterious! it has power, but now the LED bulbs won't work.
FYI, the LED work great under the hood too, much brighter and again, less juice used, fyi.
Old Jun 20, 2017 | 08:28 PM
belairbrian's Avatar
belairbrian
Keep in mind that LED bulbs are polarity sensitive. When an LED bulb doesn't work switch the contacts. In The case of the door bulb flip it the other way and try it.
Old Jun 20, 2017 | 09:06 PM
jsmcol's Avatar
jsmcol
[QUOTE=belairbrian;1594986693]Keep in mind that LED bulbs are polarity sensitive.
Brian, I had never heard that before. I just went out, tried it again, of course it didn't light, flipped it around, works perfectly!
That means the first four times I put them in I got it right without knowing it! Thanks for the info, learned something new today.
Jim
Old Dec 1, 2021 | 02:32 PM
Roadkill Poorvette's Avatar
Roadkill Poorvette
8th Gear
what size bulb goes in the door panel light? Is it the same as the 85 model year?
Old Dec 1, 2021 | 03:54 PM
jsmcol's Avatar
jsmcol
Roadkill,
I had an '86 but don't remember replacing any of the bulbs, but they appear to be similar. Try taking your existing bulb into an auto parts store and asking for the same thing in an LED. Or, look at the bulb and try to find LED on ebay. That's what I did, you can get like 6 of them for a couple of bucks.
Good luck!
To door panel light gremlin...
