VATS... Can I disable it 100%
Hello all, My son and I are trying to get a 90 C4 to run and we have no key with chip, we just put in new cylinder, small town and the locksmith wants 25 dollars a key to figure it out, and finally the chevy dealer does not have a reader. Before we put any real money into it we need to see if it starts and moves, would greatly appreciate any direction you can give... well any good direction..grin.. Thank you!
Thanks for the truth!
Any way you can call another dealership with your VIN and have them make a key with the correct pellet?
https://www.clksupplies.com/products...e-double-sided
You need a VATs interrogator. Save yourself a lot of aggravation, bite the bullet and buy something like the attached, sell it after you are done.
If the cylinder came with a standard (non-VATS) key. All you really need is a handful of resistors and some patience. probably way cheaper than $125.
Correct, you need the key for that to work. You will need the interrogator to determine what key resistance the VATs module will respond to. The other option is to make up 15 corresponding sets of resistance values, drop the hush panel, disconnect the wires coming down from the lock cyl. and try each value (harness side) and try to crank the car. Time consuming.
The interrogator is a collection of the 15 key values, with a timer function built in 4 min.
[B][/WARNING THE FOLLOWING WILL ALLOW CAR TO START WHILE IN GEARB]
make sure car is out of gear, in neutral if manual; park if auto
make sure parking brake is set
run jumper wire to small terminal on starter solenoid
place ignition switch in "ON" position
touch other end of jumper wire to positive terminal on battery
starter should engage, engine should turn over, and hopefully start
A year or two ago my local Chevy dealer would make a new key with the correct resistance for about $25 from the VIN number. Just needed to provide proof of ownership for them to make the new key. That included the price of the new key and cutting it.
I would check with another Chevy dealer if yours can't do it.
Good luck.
I checked both an '87 and a '96 service manual and both show the fuel is disabled by the ECM when the VATS does not have the right key. So it is both the cranking and the fuel that are disabled.
Good luck.
You need a $1.79 potentiometer and a multi-meter.
Remove the hush panel and find the orange wires that lead to the ignition. Follow the orange wires until you find the connector. Unfasten the connector and use the potentiometer to supply each of the 15 possible VATS resistances.
the CCM "Theft Deterrent Relay Control" energizes the low amp side of the "Theft Deterrent Relay" and that circuit is completed through the clutch pedal safety switch or the auto transmission park/neutral switch;
once this relay closes, it allows the ignition switch, in the "start" position to energize the starter;
when I looked at "Engine Controls (Injectors) 6-279 I didn't see anything that could cause the injectors not to fire, assuming the ignition switch was in the "on" or "on/start" position
But hey, I could be wrong..been wrong before; still I think my idea is worth a try.
The ECM decides how much time to pulse the injectors to make the engine run correctly. In the case of a VATS failure, it pulses the injectors zero seconds each time. Not useful.
