93 LT1 Auto Transmission Indicator not moving
Old 06-22-2017, 04:25 PM
ploftus06
7th Gear
ploftus06's Avatar
Default 93 LT1 Auto Transmission Indicator not moving
I have 93 LT1 and the automatic transmission indicator in the console does not move when I shift gears. What is the solution to this transmission indicator not moving with the gear shifter?
Old 06-22-2017, 04:51 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
You will have to pop off the center console lid and re position/fix the indicator needle. Pretty straight forward once you get the console top off.
Old 06-22-2017, 09:18 PM
pcolt94
pcolt94's Avatar
There is a stud for the indicator that goes in between a fork. It's possible the stud broke off or one of the forks broke off. When you install the center back on, the stud has to be lined up into the fork. Not much chance the alignment came apart by itself.
To 93 LT1 Auto Transmission Indicator not moving
Quick Reply: 93 LT1 Auto Transmission Indicator not moving
