91 map sensor diagnostic
Please help me with this
I stored my 91 some years and i found that several sensor are not working properly , i replaced some.
I have scanner and i can read the values
Could some body please let me know how can i diagnose if the map values are correct ?
I don have leaks at intake, yesterday i have an error code map high, this is caused by leaks or faulty map
But car runs normal
I double check vacuum hoses and evrything is correct, i recently installed bigmouth intake and siamese runners and i replaced vacuum hoses.
Then i want to check the map sensor values
Thanks in advance
