Coolant sensor thread pitches, locations
Old Jun 26, 2017 | 03:53 PM
C4Ownr24's Avatar
C4Ownr24
Default Coolant sensor thread pitches, locations
Hey all - quick question. I've got an '86 that's a bit of a frankenstein; long story short, it now has an older set of Edelbrock performer heads (these were given to me by my engine builder.) I've got the engine installed and 90% hooked up but have hit a snag w/the coolant sensors in the heads. A few questions:
a) what thread pitch are the original sensors in an '86?
b) the sensor in the intake manifold, I believe, is for the ECM. The one on the driver's side head is the fan switch, I believe - what does the sensor in the RH head do? The instrument panel?
c) the threads in the Edelbrock heads are 1/2" NPT, I believe. The goal here is to adapt the old sensors to the new heads, but I can't seem to find any adapters that do so; I suspected the sensors were 3/8", but when I try to thread the sensor into a 3/8 to 1/2 adapter, the sensor's threads seem just a bit too wide to thread in.
Any suggestions here are greatly appreciated. Cheers.
Old Jun 27, 2017 | 02:06 AM
WVZR-1's Avatar
WVZR-1
OE cylinder heads switch/sender would be 3/8-18 NPT
A 1/2 NPT to 3/8 NPT "bushing" should be an easy find. If you're cylinder heads wear 1/2 - NPT the OE switch/sender would "drop in". Sounds like you maybe don't understand NPT *OR* maybe the bushing isn't correct that you've bought. Very early SBC heads did use 1/2 - NPT senders. it wouldn't be unusual for the sender/switch threads to be very tight in the new bushing.
Right cylinder head rear would be used for the gauge sender in the cluster.
Take your bushing/adapter to a parts store and check the threads using NPT fittings from their stock.
Old Jun 27, 2017 | 02:18 AM
Cliff Harris's Avatar
Cliff Harris
Yes and yes. The passenger side temperature sensor is for the instrument cluster.
Old Jun 27, 2017 | 08:17 AM
WVZR-1's Avatar
WVZR-1
What I didn't mention in my earlier post is that I believe the sender/switch is done in NPTF and even though the pitch and thread count is the same as NPT the major and minor diameters are different and when I mentioned it wouldn't be unusual to have "very tight" threading I maybe should have explained.
This explains maybe better than I could.
http://www.ring-plug-thread-gages.co...PT-vs-NPTF.htm
When using the appropriate bushings or nipples I've never experienced a fit that I was concerned with. I've used more than a few. The *F* is a FUEL spec for NPT.
To Coolant sensor thread pitches, locations
