Window Control Module -Express Down
Old Jun 27, 2017 | 01:16 PM
ros11ens's Avatar
ros11ens
3rd Gear
Default Window Control Module -Express Down
Can anyone give me the location of the window control module (express down module) in a 1996 Corvette? I have searched this forum and there are references to it and even pictures of the module, but no location is given. Thanks in advance.
Old Jun 27, 2017 | 01:27 PM
-=Jeff=-'s Avatar
-=Jeff=-
I believe it is in the drivers door, well that is where I installed one on my 1990
Old Jun 27, 2017 | 01:39 PM
WVZR-1's Avatar
WVZR-1
OP - I believe it's in the CCM stack front of the console, lower center dash vicinity.
Get yourself a FSM and you'll have the answers at your finger tips. Diagnostics also.
Name:  '96 CCM Stack.png
Old Jun 27, 2017 | 01:48 PM
-=Jeff=-'s Avatar
-=Jeff=-
Huh.. imagine that.. I like my install location better.. LOL
Old Jun 27, 2017 | 03:14 PM
ros11ens's Avatar
ros11ens
3rd Gear
Thank you Jeff.......that was my next location to look at.
TGFF........(Thank Goodness for Forums)
Old Feb 5, 2025 | 03:17 PM
XAMOSZR1's Avatar
XAMOSZR1
6th Gear
Hey Jeff, Do you have a wiring diagram for thos mod. Want to do it in my 91.
Much appriciated.
Old Feb 5, 2025 | 03:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
I might, I need to look for the info
Old Feb 5, 2025 | 09:53 PM
-=Jeff=-'s Avatar
-=Jeff=-
Express Window Down
Have you gotten in your ZR-1 after driving a later model car and really wished you had an express window function on the window (or windows) of your Corvette? Well you are in luck, it is a pretty simple mod that can be added.
Below I have listed out the connector pigtails you will need as well as the Express module. Most of the connectors can be found on Amazon, Summit or eBay. Unfortunately the only place to find the Express Module is eBay. If you want to cut your harness and add the module you will only need the PT531, the other two allow you to make it plug and play.
This can be done on both windows but what I found on the 1990 is that I needed to disconnect the window motor connector and physically swap the pin locations on the connector for it to work correctly.
I have an image of page 8A-120-0 from a 1996 C4 manual. If you look at the Diagram there are 3 main pieces: Window Switch, Window Motor and Window Module. I felt it is easier just to cut the OEM wires and add one connector But you can follow the wiring to make your plug in harness. I will explain the wiring with one connector.
The PT 531 is the express window connector it has 5 wires, Cavities A,B,C,D,E we will use 4 only ( B is not used)
On the Window switch connector do the following:
Connect D of the switch to C of the Module connector
Connect F of the switch to A of the Module connector
Cut the wire C of the switch
Connect the Switch side of C (one you just cut) to E of the Module connector
Connect the other side of wire you cut to D of the module connector.
*note the 586 and 272 connectors need a couple wires moved to different cavities.
Making it plug and play is just doing the same thing essentially with the male and female Connectors.. For the passenger side just follow what was done on the driverside and swap the pins on the window motor and it will work the same. I have express down on both doors, works great!!
To Window Control Module -Express Down
