maf sensor
Old Jun 30, 2017 | 02:11 AM
i‘m dutch's Avatar
i‘m dutch
Default maf sensor
Could a bad MAF sensor prevent my car from starting ?
Old Jun 30, 2017 | 06:56 AM
aklim's Avatar
aklim
I think you can disconnect it and see if it starts.
Old Jul 1, 2017 | 04:13 AM
i‘m dutch's Avatar
i‘m dutch
I try but he won‘t start .
Old Jul 1, 2017 | 09:20 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Originally Posted by i‘m dutch
could a bad maf sensor prevent my car from starting ?
no !!!
Old Jul 1, 2017 | 09:21 AM
BlowerWorks
Supporting Vendor
Old Jul 1, 2017 | 10:53 AM
aklim's Avatar
aklim
Check fuel pressure, spark and injection pulse.
Old Jul 1, 2017 | 11:05 AM
WW7's Avatar
WW7
Yes a bad maf sensor can cause a car not to start.. I had it happen to me when I was shopping for a rebuilt maf sensor...I went through 3 rebuilt maf sensors and one was so screwed up it wouldn't even allow my 89 to start..When I disconnected the maf sensor the car started right up ( it ran bad but it did start).. I ended up going with a Blowerworks maf sensor , and after inserting their bin files into me tune the car ran great from then on......WW
Old Jul 1, 2017 | 12:50 PM
i‘m dutch's Avatar
i‘m dutch
I have fuel pressure and spark and pulse . I don‘t know where to look anymore .
Old Jul 1, 2017 | 02:27 PM
aklim's Avatar
aklim
You checked for a good spark? What is your fuel pressure? Is it pulsing the injectors?
Old Jul 1, 2017 | 02:43 PM
confab's Avatar
confab
I dunno what year, but my 85 started and ran with a bad MAF a couple of times.
Ran like crap, but it ran.
Old Jul 2, 2017 | 03:27 AM
i‘m dutch's Avatar
i‘m dutch
The spark is orange and i think it‘s weak but other people tell me he must run with the compression i have . ( 10088113 heads ) . I orderd a new distributor but it‘s takes 10 days to arrive . I doubt that‘s the problem because he was running before with the same spark .
The fuel pressure is 47psi and i have pulse .
Old Jul 2, 2017 | 03:28 AM
i‘m dutch's Avatar
i‘m dutch
1986 Corvette
Old Jul 2, 2017 | 03:45 AM
i‘m dutch's Avatar
i‘m dutch
The last time i stopped the engine the cooland spit out the water neck and hose .The wiring from the maf sencor wiring got wet . Is‘t possibe the 2 relays are dameged ?
Old Jul 2, 2017 | 08:58 AM
confab's Avatar
confab
Any codes in this thing? A couple of weeks ago, mine wouldn't start.. Would start and run, but ran terrible, kept flashing the check engine light, but no codes.
ECM died (again!)
Old Jul 2, 2017 | 10:14 AM
i‘m dutch's Avatar
i‘m dutch
ECM died (again!)
No codes and i try a new ecm and it still won‘t start
Old Jul 2, 2017 | 10:17 AM
aklim's Avatar
aklim
Just to clarify, you have tried a new ECM with the new chip, right?
Old Jul 2, 2017 | 11:44 AM
i‘m dutch's Avatar
i‘m dutch
yes
Old Jul 6, 2017 | 12:06 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
If the relays at the firewall next to battery got wet with coolant, wouldn't think so since connectors are face down.
I'd take them out and clean/dry them anyway, coolant is nasty.
To maf sensor
