c4 speedo display problem
Old Jun 30, 2017 | 12:12 PM
crazypaul's Avatar
crazypaul
3rd Gear
Default c4 speedo display problem
My wife drives a 92 c4 and last week when she came out of work she had a dead battery , so the guys jumped it for her and now the speedo display is going crazy. At times it works fine and then it will freeze up for awhile and then start working again. Any suggestions where I should start looking in order to repair this problem? Thanks in advance for any helpful suggestions. Paul
Old Jun 30, 2017 | 12:42 PM
belairbrian's Avatar
belairbrian
you should contact the Bryan at batee.com. They specialize in c4 corvette displays. They can fix it or supply parts if you want to DIY.
Old Jul 3, 2017 | 02:09 PM
easy2no's Avatar
easy2no
Check your alternator first. Had same problem..
Old Jul 3, 2017 | 02:12 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Start here. If you speedo was working prior to the dead battery, then to the two may very be connected.
Why did the battery die?
To c4 speedo display problem
