Help me pick a torque converter!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 1, 2002 | 05:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Help me pick a torque converter!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (EIGHTY5)
Since your '85 comes with a 2,000rpm TC stock, how much more do you need?
Why is the current TC an issue, since a higher stall will put you higher in the power band?
If you're cruzin in 3rd or 4th at those RPMs you should have TC lockup so stall realy isn't an issue till you hit the accelerator or brakes.
Old Oct 1, 2002 | 06:39 PM
vette92_1's Avatar
vette92_1
I agree with 65Z01...
But if your still wanting a TC, I think I'd go with a Yank Stealth. But 3000 RPM's..wow , I think I would stay around 2400 - 2600
Just out of curiosity...why do you think a higher stall TC will help tame that puppy?
[Modified by vette92_1, 4:50 PM 10/1/2002]
Old Oct 1, 2002 | 08:24 PM
RadPolo96's Avatar
RadPolo96
Default Re: Help me pick a torque converter!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (vette92_1)
I would agree, I got a Stealth 2800 Yank...I love it to death and after these gears I just put in, you can really feel the difference.
:cheers:
Old Oct 1, 2002 | 11:26 PM
smallblock's Avatar
smallblock
I've got a 3100rpm stall vigilante, I have absolutely no driveability issues whatsoever, go for it. With the set-up you have , you need 3.73 to 3.90 gears to optimize you performance.
Old Oct 2, 2002 | 08:57 PM
RayJay's Avatar
RayJay
EIGHTY5,
I had an LT4 HotCam added to my '96 A4 coupe and the drivability with the stock TC was pretty poor. My tuner recommended a Yank Stealth 3000 stall TC and it made all the difference for me. I have no issues with it. It was smaller and lighter than their 2800 unit. I think it lists for ~$700. It would probably be a good idea to retune the ECM after adding it, though. You might want to lower the shift points and rev limiter (if it was bumped up) to account for jumping so quickly into the upper limits of your power band. :yesnod: :yesnod:
Old Oct 2, 2002 | 09:01 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
If you still have it apart....go for the higher stall speed...JEGS and Summit have some grat prices. :)
Old Oct 3, 2002 | 12:11 AM
RayJay's Avatar
RayJay
EIGHTY5,
Yup, I've got the "performance" rear end (3.07) and so far, the Yank 3000 seems fine. I have to tell you that it's still pretty new to me so I have not put it thru all the paces but in town, it's very drivable. For the most part, I don't even notice it. Don't get me wrong , it only takes a bit of aggressive throttle and the tires spin. For me though, I have not had any problems.
Old Oct 3, 2002 | 11:09 AM
fullboogie
Default Re: Help me pick a torque converter!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (RayJay)
I'd call the tech guys at the manufacturer of each converter you're considering, and talk to them. No offense to us forum participants, but the pros are the guys to ask about this.
To Help me pick a torque converter!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
