Accessing G104 Bellhousing Ground
Old Jul 2, 2017 | 10:40 PM
duowing's Avatar
duowing
Default Accessing G104 Bellhousing Ground
I've been trying to look for tips on how to do this. I was under the car and I could not for the life of me figure out how to get at this bolt. Does anyone have any tips on how to loosen this bolt, and then putting it back in? I'm going around trying to clean the grounds and eliminate issues with this car.
Old Jul 3, 2017 | 03:09 AM
Cliff Harris's Avatar
Cliff Harris
You have to remove the exhaust system. Maybe there's a way to do it without removing the exhaust system, but I couldn't figure it out.
Old Jul 3, 2017 | 10:32 AM
383vett's Avatar
383vett
9/16 box wrench or 9/16 swivel socket work. I take my motor/tranny out so often I opened a hole to the right of the gas pedal to access the bolt with a straight socket and air ratchet.
Old Jul 3, 2017 | 11:16 AM
WVZR-1's Avatar
WVZR-1
I understand the "access hole" - access hole and a cap plug to fill it!! In your case likely isn't filled!
Old Jul 3, 2017 | 02:10 PM
383vett's Avatar
383vett
You, my friend, are correct. No cap plug for this car.
Old Jul 7, 2017 | 12:12 AM
Hoser's Avatar
Hoser
Default Bellhousing ground
I dropped the AT shift cable bracket and went in with a 24" extension and a couple of short extensions to give the overall extension some "flex".
Hope you don't have to reattach any terminal ends, thats when it really gets fun😊
To Accessing G104 Bellhousing Ground
