traction problems
Old Oct 1, 2002 | 09:53 PM
atotalnincompoop's Avatar
atotalnincompoop
Default traction problems
i'm having a problem with wheel hop under hard excelleration, anybody know of a fix? :cheers:
Old Oct 1, 2002 | 09:58 PM
95AquaC4's Avatar
95AquaC4
Default Re: traction problems (atotalnincompoop)
:confused:
Old Oct 1, 2002 | 10:05 PM
atotalnincompoop
Default Re: traction problems (95AquaC4)
i can't believe that noone has had this problem before
*you need to crop your sig*
[Modified by Mr Mojo, 10:00 PM 10/1/2002]
Old Oct 1, 2002 | 10:52 PM
KyleBst264's Avatar
KyleBst264
Have you changed the tires recently?
Has anything been changed or altered in the rear suspension?
[Modified by KyleBst264, 9:52 PM 10/1/2002]
Old Oct 1, 2002 | 10:53 PM
atotalnincompoop
Default Re: traction problems (KyleBst264)
i installed a set of 18" wheels off of a c5
[Modified by Mr Mojo, 9:59 PM 10/1/2002]
Old Oct 1, 2002 | 11:02 PM
vette92_1's Avatar
vette92_1
I don't know if it would have anything to do with it or not, but it does appear that the rear of the car is a lot higher than normal. I wouldn't think it would matter but maybe the suspension being at a different angle has something to do with it. Did it do it with the old tires and wheels? Did it set level or normal with the old tires and wheels?
:confused:
I would check shocks and monospring.
[Modified by vette92_1, 9:13 PM 10/1/2002]
Old Oct 1, 2002 | 11:08 PM
atotalnincompoop
Default Re: traction problems (vette92_1)
the suspension is stock, i haven't lifted or lowered it. as far as the tires go, i think that the tires 275/40r18 are about the same hieght as the original 255/50r16 :cheers:
[Modified by Mr Mojo, 12:07 AM 10/2/2002]
Old Oct 1, 2002 | 11:10 PM
atotalnincompoop
oh ya, it didn't hop before, however it was a sucked out stock '85, now it is quite a bit more powerful
Old Oct 1, 2002 | 11:16 PM
vette92_1's Avatar
vette92_1
Hmm, it just looks a lot higher in the rear for some reason. Anyway, I don't no if you noticed, but I added to my earlier post, the only thing I can think of is shocks and or monospring. Good luck
[Modified by vette92_1, 9:17 PM 10/1/2002]
Old Oct 1, 2002 | 11:19 PM
atotalnincompoop
it might just be an optical illusion or something, the car sits at the stock height, id like to lower it a bit, but it already scrapes the roads around here so i'll leave it for now. i'll go to the local speed shop tomorrow and see whats available. thanks for you help :cheers:
Old Oct 1, 2002 | 11:35 PM
bogus's Avatar
bogus
rear wheel hop can be caused by a bad alignment. also, yours is getting a bit older now, and the bushings or rear tie rods could be worn out.
also, here is a trimmed down version of your sig pic...
Old Oct 2, 2002 | 12:29 AM
C4Dreams's Avatar
C4Dreams
Default Re: traction problems (bogus)
Tire pressure...I had to mess with this on my Buick Grand National 500+HP...def mess with it...if your at the track hit the low #s..
C4Dreams
just my .02
Old Oct 2, 2002 | 12:43 AM
Wheelman's Avatar
Wheelman
if you have runflat tires they can cause wheelhop issues too.
Old Oct 2, 2002 | 12:47 AM
scorp508's Avatar
scorp508
Get the car aligned. The 18" rims have much less sidewall so the tire can't really "dig in" and go allowing them to skip along.
Old Oct 2, 2002 | 07:06 AM
MCAF84's Avatar
MCAF84
Had that happen once. My suspension is all rebuilt with poly bushings and new springs With a fresh alignment to my specs What caused the wheel hope was to low tire press I had 12# in my road race tires I bumped it up to 24# the wheel hop went away This worked for me
Good Luck
Mike
Old Oct 2, 2002 | 10:22 AM
atotalnincompoop
Default Re: traction problems (MCAF84)
well the tires are run flats and my suspension is probably tired, so i'll nurse it until the snow flies and then address these things this winter. thanks all :cheers:
Old Oct 2, 2002 | 10:24 AM
atotalnincompoop
i haven't been able to figure out how to trim my pic down can you email it to me? atotalnincompoop@hotmail.com thanks :cheers:
To traction problems
