Breaks 1986 c4
Old Jul 11, 2017 | 11:06 PM
Fun1986's Avatar
Fun1986
4th Gear
Default Breaks 1986 c4
Can not get break pedal to stay firm new master cylinder
Old Jul 11, 2017 | 11:10 PM
Fun1986's Avatar
Fun1986
4th Gear
Have blend breaks many times no air good breaks then none please help
Old Jul 12, 2017 | 07:55 AM
s carter's Avatar
s carter
You say you have bled the system and I don't doubt you did so let's move on from there. next are you loosing fluid, when the peddle is Not firm does the car still stop well.
Because there is a Slight chance your new master is defective and Stroking thru on occasions.
Old Jul 12, 2017 | 08:19 AM
Fun1986's Avatar
Fun1986
4th Gear
Default Brakes
Not losing fluid and car doesn't stop well when this happens
Old Jul 12, 2017 | 08:28 AM
JimLentz's Avatar
JimLentz
Did you bleed the master separately?
Old Jul 12, 2017 | 08:45 AM
s carter's Avatar
s carter
Good Point if didn't Bench bleed and ex-spelled the last bit at the master connection odd's are you have pushed a lot of air into the system. If you did all that and you say the brakes are poor when it happens and the brakes are good and then their bad.
YOU HAVE A BAD MASTER
Old Jul 12, 2017 | 08:46 AM
81c3's Avatar
81c3
Bench bleeding is a huge step in getting the air out of the system.... Have you had help bleeding the system? Start with the farthest bleeder from the M/C and work toward the closest. If youre employing a helper, have them pump the pedal very slowly, 2-3 times, then crack the bleeder... while the helper holds the pedal down, tighten and repeat a few times per bleeder.... do all of them this way always keeping the M/C full.... then go around to each and do it again... and again.... until the pedal is firm and the air is all out.
Old Jul 12, 2017 | 09:35 AM
Fun1986's Avatar
Fun1986
4th Gear
Have done this about 8 times to same end point great brakes the none then great than none
Old Jul 12, 2017 | 12:45 PM
s carter's Avatar
s carter
​​​​​​​. If you have gotten all the air out and the brakes are good then the pedal drops and Dosn't want to stop master is bad
Old Jul 12, 2017 | 01:27 PM
81c3's Avatar
81c3
The crux of the issue is.... did he get all the air out?
To Breaks 1986 c4
