Oil pressure light
Old Jul 18, 2017 | 04:57 PM
MAXWCH1's Avatar
MAXWCH1
1st Gear
Default Oil pressure light
My 1989 Corvette oil pressure light comes on only when idling, but once I start going the pressure comes up and light goes off.
Old Jul 18, 2017 | 05:13 PM
aklim's Avatar
aklim
Have you checked the oil pressure with an independent gauge to see if it is really an issue?
Old Jul 18, 2017 | 09:45 PM
xrav22's Avatar
xrav22
Can I ask what the dash is reading at idle, I am usually at 15-20 pds(Corvette). My Range Rover had a light issue at idle and it was the oil pressure sensor(bought a cheapie). Good Luck
Old Jul 19, 2017 | 07:55 AM
markKlein's Avatar
markKlein
I had a similar problem. I didn't react fast enough and it cost me an engine. Pressure should never be below about 10 psi.
Old Jul 19, 2017 | 08:23 AM
GRIS's Avatar
GRIS
HAD THE SAME PROBLEM WITH MY '87, TURNED OUT TO BE THE SENDING UNIT.
To Oil pressure light
